A
Anonymous Posted on Jul 10, 2019
Can I get advice about a scanner that is not working?
Patrik Parker
Level 3:
Master:
  • Master 148 Answers
  • Posted on Jul 10, 2019
Patrik Parker
Master
Level 3:
Master:
Answers
148
Questions
5
Helped
8389
Points
2578
Call Our Customer Service For Help and Support Call 1 8O5*465*751O Toll Free
24x7* Now Tech is Available cal Now
2helpful
2answers
GENIUS COVERPAGE-HR8 Scanner
deseo instalar un scaner color page-vivid III v2 en windows XP, se puede? como?
Scanner doesn't work with Windows Vista
Unfortunately this scanner is at end of life and I do not think you will find any drivers for Vista.
Benq scanner
did you try to uninstall driver completely and fater did you reinstall the driver ?
1helpful
Duo scan for Mac
Hi !
Bad luck...!
We had the same problem...
The original FOTOLOOK-program DOES NOT work on Mac OS 10.4 ...!
Advice: buy VUESCAN (professional-version - USD 79), works great & life-update for program...!
Grtz, H.
2helpful
2answers
CanoScan N1220U Scanner properly installed but not workin
This doesn't do "one button" scans, but I just downloaded "VueScan" for my 10.5.4 Intel Mac and the demo is working great with my Canoscan N1220U.
http://www.versiontracker.com/dyn/moreinfo/macosx/7610
7helpful
5answers
Kodak 2500D error
I have had the same problem. That error represent a document still in the scan path. You will probably find there is no paper in the scanner. I tried this and it works every time. On the top of the scanner there is an access door. You will find this just above the discharge rollers. Open that door and either blow air in the compartment or blow hard using your mouth to clear dust. Close the door. That should resolve the problem. It is my guess that dust collects on sensors and the scanner is tricked into thinking there is paper in the path.
Epson 2580 scanner
The only thing I can think of is to turn you to be scanned image up side down in the scanner bed.. IE Rotate 180' As another work arround simply open up Paint etc,and rotate the image 180' and save, ya should be all good.
IBM Powerd USB not working
Are you using a USB 2.0 port?
Try a different USB cable.
PSC QS6000 Plus FAQ
Nov 28, 2006 • PSC QS6000
k24674
ADMIN Andrew
ADMIN Andrew
