Check input or source
SOURCE: White colour is displaying as yellow
Your monitor is missing blue drive. Most likely a component failure on the CRT board. Bad color ICs, bad solder connections or defective capacitors can cause the problem.
SOURCE: tv picture going green
hi there, you have a color section or video section problem, check the crt board, there may be and open resistor or jumper, check those transistor driver too. check the small board at the back of the crt tube, do some test and see any cold solder. ty
SOURCE: Sansui SAN1880 80g dvd recorder no colour
Hi, I have a Sansui Model San1880, after I have manually program the TV channels, I don't get no sound at all only on the TV channels its got good pictures but no sound, would you please tell me what to do.
Thanks
Rod
SOURCE: In My sansui k2k21 flat tv showing red colour more
you do not have a CRT in your flat panel set.. What you might have is your color setting to high causing the bleed or your
T-con board is bad , but first turn down your color if that does not do it have a tech replace your
T-con board
SOURCE: black and white dstv
look on the TV menu for (system) in south africa we use PAL, if you cant change it on the TV, with the decoder remote press menu then 7 then 4, it will ask for a pin code press 9-9-4-9 it will read "RF modulator" press OK, it will then read 1 MODULATION press ok again and it will highlight PAL I now press the right key and press OK, if this persists then the decoder it probably faulty... good luck
