I recently purchased an OTT TV box and find that the remote that was supplied is completely inadequate. It has no AV buttons (stop, start, pause). How do I reprogram a better remote? I am also only able to open the Netflix app - all the others (including Google Play) just return me to the Home screen. Please could you help me. Many thanks Kevan
SOURCE: 30HF85 TV with CT-877 remote, which doesn't work.
I had the same problem with my remote...over time it slowly stopped working. (sorry for poor terminology) I noticed that one of the battery terminals was corroded and that the metal connecting the battery to the board was completely gone. I simply swapped this out with one from another remote and now its working fine. Seems the only issue is that the battery was not connected.
I hope this helps.
SOURCE: HTC touch HD is completley frozen
If you have all your items saved to your computer with Active Sync, then do a master reset:
HTC Touch hard reset
14 January 2008
You can also get tips & tricks from www.htcwiki.com
It has the latest and great updates, software, even known issues if you ever come across this. HTC does recommend that you do a master/hard reset once a quarter to keep it moving smoothly. Also, ensure you don't have a lot of open running programs. Perhaps once a day, clean the cashe and history. Do a soft reset (aka battery pull) once or twice a week. All depends on how hard you play with this lovely PDA device!
SOURCE: My Sanyo TV remote AV button has failed. Is
Why would I tell you how I fixed my problem if I have to pay you to tell me.
SOURCE: the Netflix app on my
I had the same problem with my Vizio XVT473SV. I couldn't find the Netflix Activation Code. When I clicked on the Netflix App, the TV would ask me if I wanted to connect to Netflix, then it would ask me if I was a Netflix member. After clicking yes to both, it would tell me it couldn't connect to the Netflix server, check with Netflix.com/tvhelp. After a couple hours of troubleshooting, the solution was......your first use of the Netflix App has to be via the Ethernet Port/Cable. This will give you a screen with the Activation Code, after you activate the code in your Netflix account, you can go back to using WiFi on your Vizio TV to connect to Netflix. Step by step instructions are...
1) Exit the Vizio Netflix App.
2) Physically connect an Ethernet cable to your broadband (just temporarily)
3) Check to make sure the Vizio is using the Ethernet port and not your WiFi (Apps Button - HDTV Settings - Network...may have to reboot the TV to get Ethernet port connection)
4) Start the Vizio Netflix App
5) Click OK to start the Netflix App
6) You should now see a different screen that gives you the Netflix Activation Code.
7) On your Computer, Login in to Netflix,
8) Click on "Your Account & Help" link on upper right corner
9) Scroll down to Watching Instantly on your TV or Computer section
10) Click on Activate a Netflix Ready Device
11) Enter the Activation Code shown on your Vizio TV and click Activate
12) Once your Netflix account (on your computer) shows it is active, your Vizio TV will automatically log in. You should see your Instant Queue.
13) Exit the Netflix App, unplug the Ethernet cable, Turn Off your Vizio TV.
14) After 20 seconds or so (remember the TV is software driven), turn the TV back on and your WiFi should connect again.
15) Use your Netflix App and this time it should automatically connect via WiFi
note: just make sure that your wireless DSL/Cable Modem or Wireless Router is not blocking your WiFi connection request from the Vizio. You can check the connection status in the modem/router or in the Vizio in the HDTV Settings - Network.
SOURCE: Just purchased a Vizio 37" HDTV with Netflix app
The Vizio does not have Internet capabilities. You need to hook up a computer via the VGA or HDMI port. Then youor computer controls what you do with the intenet.
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
