Question about Sprint Cell Phones
I have a hot pepper phone through Sprint through terracom how do I setup the apn and service
Settings for apn are blank. what is my apn code
Hi Edward,
Here are the steps..
Internet Setup
Step 1: Enter Settings
Step 2: Select Wireless & Networks
Step 3: Select More...
Step 4: Select Mobile Networks
Step 5: Ensure Data Enabled is checked (enabled).
Step 6: Select Access Point Names
Step 7: Create a new APN (Select Menu, followed by New APN). Enter WIND Data as the name for the new APN. Under the headings APN enter internet.windmobile.ca (leave all other fields blank).
Step 8: Save the APN settings by selecting menu and then save.
Picture Messaging (MMS)
Step 7: Create a new APN (Select Menu, followed by New APN). Enter WIND MMS as the name for the new APN. Under the following information in the listed headings:
  • APN: mms.windmobile.ca
  • MMSC:http://mms.windmobile.ca
  • MMS Proxy: 74.115.197.70
  • MMS Port: 8080
  • MCC: 302
  • MNC: 490
  • APN Type: mms
  • Leave all other fields blank.
Android 2.1 to 2.3
Internet setup
Step 3: Select Mobile Networks
Step 4: Ensure Data Enabled is checked (enabled).
Step 5: Select Access Point Names
Step 6: Create a new APN (Access Point). Enter any name you would like to call your internet connection and the access point as internet.windmobile.ca (leave all other fields blank).
Picture Messaging (MMS) setup
Step 6: Create a new APN (Select Menu, followed by New APN). Enter WIND MMS as the name for the new APN. Under the following information in the listed headings:
  • MMSC: http://mms.windmobile.ca
  • MMS Port: 8080
  • MCC: 302
  • MNC: 490
  • APN Type: mms
May 10, 2016 | HTC 7 Surround T8788 Windows 7 Wm 3.8"...
I can't send or receive photos from my new phone
Rosa
Go to Settings > Mobile Networks > APN and then reset the settings to defaults using three dot button in upper right. This should deregister to network and hopefully push setting to your phone. If not. Call StraightTalk if it doesn't work.
I also searched Moto G APN for MMS and got multiple results though I want sure if you are using Sprint/Verizon or AT&T.
Mark
Motorola Support
Apr 17, 2015 | Motorola MOTO G XT1033 8GB Unlocked GSM...
Sprint unlock code
i have samsung galaxy note3 sprint,i want unlock use any sim .when i go overse.how much,let me know,thanks
Jan 11, 2014 | Samsung Cell Phones
Unlock net10
I've never used a BB storm 9530, but if phone/sms is working but data is not you do not have the APN settings for Net10. The correct APN Settings are here: http://apn-settings.com/net10-apn-settings-easy-setup-guide/
Nov 03, 2017 | RIM BlackBerry Storm 9530 Smartphone
How to add apn for sgh a597 on straight talk
AT&T phone on Straight Talk (sprint)? Unfortunately, AT&T uses GSM which is not compatible withSprint's CDMA technology.
Straight talk runs on the Sprint network, same as Boost and Tracphone. Although some phones are the same, some only work on certain networks.
Sep 04, 2012 | Samsung sgh-a597 - Sgh-a597...
How to subcribes packet data?
The common way is requesting to your cell phone carrier a flat data plan to have Internet access from your phone, when subscribed they setup your phone (APN setting) at their costumer service office or remotely using OTA (Over The Air) programming.
Mar 07, 2011 | Cell Phones
I cannot setup internet
at first plz contact your service provider to know their apn name..
then go to the connection settings in your mobile phone..create a new access point(or access profile)...choose any name and in the apn name option ..change it to your service provider apn..
Feb 03, 2010 | Motorola Mobility MOTOROKR E6
I HAVE A CLARO ACCOUNT BUT CANNOT GET INTERNET
I found these internet settings for Claro from another website:
http://forum.itechinnovations.com/index.php?tid=101
Claro's Internet Settings are:
WEB CLARO & Java Claro
homepage: http://internet2g.claropr.com
APN: internet.claropr.com
Port: 8080
username:
password:
authentication: none
Primary DNS: 0.0.0.0
Secondary DNS: 0.0.0.0
IP address:
WAP CLARO
HOME: http://wap2g.claropr.com
PROXY: 10.50.38.3
Port: 8799
APN:wap.claropr.com
MMS CLARO
Homepage: http://mmsg.claropr.com:1021/mmsc
APN: mms.claropr.com
PROXY: 10.50.38.3
Port: 8799
username:
password:
IP address:
This is how you set it up on your phone. Just substitute the settings provided with the ones above:
From: http://www.tomshardware.com/forum/49719-36-a008-ming-xing
The setup of WAP and MMS on your DUALSIM Mobile Phone is carried out in 4 stages.
• MMS Data Account Setup
• MMS Setup
• WAP Data Account Setup
• WAP Setup
Step 1 – MMS Data Account Setup
1. Go to the following menu “MENU > SERVICES > DATA ACCOUNT > GPRS > Select an empty Account”
2. Edit the following parameters in the account
a. Account Name = OptusMMSGPRS
b. APN = mms
c. User name = [blank]
d. Password = [blank]
e. Auth. Type = Normal
3. Exit back to MAIN SCREEN.
Step 2 – MMS Setup
1. Go to the following menu “MENU > MESSAGES > MMS > MMSSETTINGS > SERVER PROFILE > SIM 1 or 2 > Select an emptyAccount”
2. EDIT the following parameters in the account
a. Rename Profile = Optus MMS
b. Homepage = http://mmsc.optus.com.au:8002
c. Data Account = OptusMMSGPRS
d. Connection Type = WAP
Proxy Address = 061.088.190.010
e. User Name = [blank]
f. Password = [blank]
3. BACK then ACTIVATE PROFILE and exit back to the MAIN SCREEN.
4. Your Phone is ready to access WAP and MMS services.
Step 3 – WAP Data Account Setup
a. Account Name = OptusWAPGPRS
b. APN = prepaidyesoptus
Step 4 – WAP Setup
1. Go to the following menu “MENU > SERVICES > WAP >SETTINGS > EDIT PROFILE > SIM 1 or 2 > Select an empty PROFILE> EDIT PROFILE”
a. Rename Profile = Optus WAP
b. Homepage = http://networker.optus.net.au/wap/index.wml
c. Data Account = OptusWAPGPRS
Proxy Address = 202.139.083.152
Hope this helps!
WizardRepair
Jul 17, 2009 | Cell Phones
Mobile gprs settings
Primary Service Type : HTTPS
Primary IP : As per service provider
Primary Port : 8080
Secondary Service Type : WAPS
Secondary IP : As per service provider
Secondary Port : 8080
Home Page : http:// (As per service provider)
Bearer Type : GPRS
Apn : As per service provider
Jan 11, 2009 | Motorola Mobility W230 Phone US with...
Cell Phones Logo
69 people viewed this question
Top Sprint Cell Phones Experts
Vernon Taylor
john h
Are you a Sprint Cell Phone Expert? Answer questions, earn points and help others
