When trying to preheat oven an error code of f4 flashes and the beeper beeps until you cancel it. What does the f4 flashing mean?
Slone, F4 is the code for a shorted temperature sensor. This is the temp probe in the oven. There are 2-quarter inch screws holding it on. It should pull out through the insulation until the quick connect comes through. If you want to make sure, the sensor should ohm out at 1143 ohms at 100 degrees. I think you can be pretty sure that this is the problem. The part number I have is 704657. Catriver.
Thanks,
I'm sure that this is the problem, I'll check around for the part and give it a fix.
Thanks again.
Update, got the part and fixed it myself and the oven works!
Thanks for all your help, if we have any other problems we will be logging back for advice.
I have the same problem, the F4 error. Please help me.
