I have a kodak m863 i just got the charger it hasnt been turn on in a while. i plug in the camara and it turns on only to the point were the lens pop out then it shuts off. but if i take the charger off the camara wont turn on at all.
Here are the steps:
1. Make sure you will install a new or fully charged battery/batteries into your camera.
2. Clean the battery contacts.
a. Remove the battery/batteries and the memory card from your camera, then wipe the battery contacts with a soft, clean cloth.
b. Reinstall the battery/batteries into your camera
3. Without the memory card,turn on your camera.
If issue persists, call 1.800.235.6325 for repair.
Thanks.
Neerak21
Try removing the battery then use the 5V AC adapter then power on the camera
if the camera turns on try using the battery
