Question about LG Televison & Video
LG FLAT SCREEN Model no: 42LN5100-TA has sound but no screen remain black, I have unplugged HDMI and all cables for 5 minutes but screen still black ?
    Habit-Forming:
    New Friend:
  • 157 Answers
You have a back lighting problem. Take the the back off, and do the flashlight test, to see if there is a picture. If you see a picture then it's a LED problem, ( there like Christmas tree light one go out they all go out ) or, it also could be a bad power supply board. I suggest a new power supply board, to see if that solves the problem. If you still have the same problem then you know it's a bad LED light strip.
Posted on Jul 11, 2019
    Top Expert:
  • LG Master
  • 76,204 Answers
Back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis.
http://homenol.blogspot.com/
http://electro-medical.blogspot.com/
For some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement. To some models sets, the back-light inverter and SMPS section circuit will be integrated at its main board itself. If so; the main board should be replaced. To some models of sets, all these section circuit will be integrated at its main board. If this is the case, you have to replace the main board.
Search the site by type in the "brand name" of your device; [Exclude the model number], in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
{View the site in web view or by a desktop to see the search box. Mobile view has no search box.}
6ya staff
SOURCE:
Anonymous
SOURCE: TV screen went black, sound OK
check cold solder vertical circuit
Posted on Feb 19, 2007
Anonymous
SOURCE: goodmans flat screen TV.Blank screen
If it is a LCD TV, and there is a faint picture, it is probably the backlight or inverter board (probably the latter). This is a common problem (especially with PC monitors).
Do an internet search for your model and inverter, you may be able to replace it.
Make SURE you REMOVE the power lead before opening the set !!!!
Posted on Mar 03, 2008
RescueTechLA
RescueTechLA
  • 2653 Answers
SOURCE: about 5 - 10 minutes into gaming, the screen will
No, cables RARELY go bad. More than likely it's the GPU on the motherboard. It's getting too hot.
You need to get some compressed air and blow out all the dust. It's best to do it outside ;)
Also give it about a minute or two before powering up again.
It also helps to use the PS3 in a vertical position, heat is your enemy!
Let me know what happens after following my suggestions.
--RescueTechLA
Posted on Nov 28, 2009
Chi Chu
  • 8457 Answers
SOURCE: screen went black...audio still working..Shuts off
Ur LCD inverter backlight board is dead.Replaced this LCD inverter backlight board.U will get ur picture back.Tries websites Shopjimmy.com,Ebay.com to buy a refurbish LCD inverter backlight board for the replacement.It a long board in shape.
Posted on Mar 15, 2010
SOURCE: screen and sound cut out while watching TV
http://online.manualspace.com/television-manuals-free-ebook/lg-television-service-manual/5319/lg-32lx4dc-lcd-television-service-manual-168.html
Above is a service and repair manual, use this to troubleshoot your unit.
Posted on May 11, 2010
My LG tv will go on then after a few seconds the screen goes from black back to picture of and on a few times then shuts off. Help!
LG LED TV has no picture (black screen) but still sound ...
www.tomsguide.com/answers/.../led-picture-black-screen-sound-fixed.ht...
7 days ago - My 32' LG LED TV has suddenly lost picture! The sound is all right but theScreen is pitch black. After switching it on the picture flashes for a second and thenthe ... LG LED TV has no picture (black screen) but still sound - can it be fixed? Tags: ... a touch on the screen reveals nothing so it's not the back light.
Monitor going black after 2 seconds [Solved] - CCM.net
ccm.net > Forum > Hardware
Oct 9, 2012 - Brightness goes down, display draws less juice, and you can at least use .... it's the LCD's Inverter ... you have to replace it for it to go back to ... If the screen is turning off every two seconds or so and then it comes ... i turn my tv on it comes right on, but then after a few minutes turns off, .... Digital Trends for LG. No display in monitor
Jan 11, 2013
Ps3 and hdmi cable
Oct 8, 2012
More results from ccm.net
TV with Black Blank Screen Repair How to Troubleshoot ...
? 3:16
https://www.youtube.com/watch?v=kFdVi2ejfzA
Dec 20, 2015 | LG Televison & Video
My LG LED TV suddenly had black screen as I was watching. There is volume (sounds) coming from it but the screen is all black. What is wrong with it?
Not a good sign... reboot, and try again, if no display but audio, then check HDMI cable or whatever source cable you have by wiggling it to see if video comes back, if no, then most likely repair..
Feb 26, 2015 | LG Televison & Video
Onkyo HDMI + 42 " LG TV = black screen but both work fine with other inputs/ outputs
If using a box disconnect it and the set from power for a few minutes and try again.
Next I would remove connections one at a time with set off and try to see if one is creating this issue. HDMI does not like to be connected when a unit is on or power connected to it.
Dec 23, 2012 | Televison & Video
I have a black screen when I connect the HDMI cable. When I connected it originally it worked for about 5 minutes but now I get nothing but the black screen. I tried connecting a different HDMI cable to it...
The main reason of HDMI black screen problem due to HDMI cable may damage and not proper connected to the PS3 console. Please follow below step to troubleshoot PS3 HDMI cables problem:1) Restart your PlayStation 3.
2) Look for loose cables.
3) Try to unplug all cables except the power cord, and plug them back in. If you found out that your HDMI cable is damage, do borrow your friend cable and have a try. If your friend cable work fine, and the black screen error disappear. Then you can buy a brand new HDMI cable for replacement.
Tips 2: If tips 1 not working, you need to go another step deeper by reset your console. Most of the PS3 gamers not aware that Sony actually done include in the black screen troubleshooting method and other HDMI problems in the PS3 manual, you can find it under troubleshooting section - topic "console reset".
If you do it correctly, the console reset fix will allow you to reset back your PS3 to its default HDMI settings without impacting your gamer profile, and other storage data in hard drive.
You will need to perform the following steps:
1. Place your PS3 in stand-by mode.
2. Hold down the touch power button until a series of beeps are heard.
3. Listen for one long beep, followed to two shorter beeps.
4. Release the power button.
5. Follow the instructions on screen.
Jan 11, 2011 | Sony Playstation 3 (PS3) Console
47LG70 - PICTURE WENT OUT. STILL HAVE SOUND. HEARD A POPPING NOISE WHEN PICTURE WENT. TV IS ONLY 1 1/2 YEARS OLD. ANY IDEAS WHAT MAY OF HAPPENED.
I have had the same problem off and on with my 47LG70 for months. When the "popping" noise happens, the blue light in the corner stays on, so I know the tv is still on (sometimes I still have sound, sometimes I don't). Sometimes the screen goes black, but other times it is blue. If I turn the tv off then on again, it might stay on for seconds, minutes or hours. It's been very frustrating.
This seemed to happen right after I got my new Comcast box, which came with an HDMI 1.3 cable. I read somewhere online that this tv might not be compatible with that cable, so I unplugged it and am using component cables again. I just did this today, so I don't know if it will work, but so far the tv has been on for 30 minutes with no problems.
I'm pretty ignorant about HDMI compared to component cables. I imagine I will not get as good a picture with the component cables, but I am willing to sacrifice quality if I can just get the darn thing to work. Mine is also only 18 months old.
Hope this helps. If it doesn't, maybe someone else out there can help us both.
Sep 21, 2010 | LG 47LG70 42 in. LCD TV
LG 42PC56 ps3 best settings?
Your PS3 should detect when you set up a HDMI connection then just follow the onscreen instructions. If it does'nt unplug the HDMI cable and use the scart cable. Then unplug the scart cable and plug in the HDMI cable your PS3 should detect this HDMI cable and it will notify you on screen.
Hope this helps
Terry
Apr 06, 2009 | LG 42PC5D Television
HD Problems
ya buy new hd antenna non powered sound like antennna messing up
Jan 06, 2008 | Televison & Video
Televison & Video Logo
109 people viewed this question
Ekse
RONALD CARTER JR
