Sharp 25R-S100 25" TV Logo
Chris Martin Posted on Dec 05, 2007
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Infrared sensor not working
I posted to Wronny68's question about his remote control. I don't believe the TV is responding to the remote control. I did try a new one, making sure it worked on other devices in my house fine. Took the TV apart to make sure the iR receiver was not obstructed by dust, etc. Wondering if a solder joint could be the problem? The TV is NEVER moved or bumped or jarred, so I'm not sure how the solder joint would come loose? Any suggestions? Would the "eye" go bad, stop working, and if so, are there replacements?
  • rosalinddors Feb 16, 2009
    the remote control sensor on my 32'' curtis mathis television won't respond to the remote control.
Rommel Balcita
Level 3:
  • Master 749 Answers
  • Posted on Dec 05, 2007
Rommel Balcita
Master
Level 3:
Answers
749
Questions
Helped
376965
Points
2156
Try changing your remote's battery and look for loose connections inside the remote control
  • Rommel Balcita Dec 05, 2007
    check if the IR diode is loose.
1helpful
MY 32FPL5606h/58 isn't responding to the remote control. My remote controls are working as i see the infra red when i push some buttons. But the TV isn't responding. Help!
Check the remote control for its infrared emission. Check it with fresh batteries. Check it by pressing all the keys. You can detect the presence of infra-red emission from the remote control, using a cell-phone camera. If you wish to get more details about how to check a remote control, please visit this site. One among the posts has details about it. In some cases, the remote control might need to clean.
http://remotesearch.blogspot.com/
Search the site by type in this key phrase "how to test a remote control "in the "search box at the top right of the display window of the Homepage" to get the related post quickly.
https://youtu.be/wUpnETSm6_k
https://www.youtube.com/watch?v=jsSCNCW3IbQ [open and clean]
https://www.youtube.com/watch?v=Qp-l1uh-5gE [open and clean]
If remote control is working properly, the fault is with the infrared sensor circuit inside the TV. Check and replace the infrared sensor.
It quit responding to both my remotes
Check the remote control for its infra-red emission. Check it with fresh batteries. Check by pressing all the buttons on it; and see whether all of it generates infrared signal while pressing. If it is found OK, check and replace the infrared sensor inside the TV. If you wish to get some details; check the site linked here. It has details about how to check a remote control; by one among the post. Surf the site with patience. Pull up older posts. If the remote control is found OK; check and replace the infra-red sensor inside the TV. Contact any service technician.
http://electro-medical.blogspot.com/
Why is my JVC TV not responding to working remote?
Check the remote control for its infra-red emission. Check it with fresh batteries. Check by pressing all the buttons on it; and see whether all of it generates infrared signal while pressing. If it is found OK, check and replace the infrared sensor inside the TV. If you wish to get some details; check the site linked here. It has details about how to check a remote control; by one among the post. Surf the site with patience. Pull up older posts. http://electronicshelponline.blogspot.com/ If the remote control is found OK; check and replace the infra-red sensor inside the TV. Contact any service technician
2answers
Remote and manual buttons don't work
If the panel lock is set to ON, the panel buttons won't work. If the remote control or the infrared sensor inside the TV is faulty; the remote control won't respond. Contact any service technician. Check the remote control for its infra-red emission. Check it with fresh batteries. Check by pressing all the buttons on it; and see whether all of it generates infrared signal while pressing. If it is found OK, check and replace the infrared sensor inside the TV. If you wish to get some details; check the site linked here. It has details about how to check a remote control; by one among the post. Surf the site with patience. Pull up older posts. http://electronicshelponline.blogspot.com/ If the remote control is found OK; check and replace the infra-red sensor inside the TV. Contact any service technician
1helpful
The TV no longer responds to the remote control i know that the problem is the TV not the remote control
Check the remote control for its infrared emission. Check it with fresh batteries. If it is found OK, check and replace the infrared sensor inside the TV. If you wish to get some details; check the site linked here. It has details about how to check a remote control; by one among the post. Surf the site with patience. Pull up older posts. http://electronicshelponline.blogspot.com/
If remote control is found correct, check and replace the infrared sensor inside the TV
Why remote control for samsung model ua40e5600 not working
The remote control sensor is not responding
Check the remote control for its infrared emission. Check it with fresh batteries. If you wish to get more details about how to check a remote control, please visit this site. One among the posts has details about it. Surf the site with patience.
If the remote control works fine, replace the infrared sensor inside the TV.
Tv not responding to remote control
Check the remote control for its infrared emission. Check it with fresh batteries. To get some details, http://electronicshelponline.blogspot.com/ Pull up older posts. Details about how to check a remote control are given. If the remote control is found OK, check and replace the infrared sensor inside the TV.
Tcl 21k77b
Check the remote control for its infrared emission. If it is found OK, check and replace the infrared sensor inside the TV. If you wish to know how to check and repair a remote control, how to replace the infrared sensor, check this link. http://electronicshelponline.blogspot.com/ Pull up previous posts there, either by its left side bar, or view it in Timeslide option.
1helpful
Toshiba 32a14 does not respond to remote control
Hello
There is a infrared light sensor inside the TV which detects the infrared rays emitted from the remote control, when we press each button on the remote control. If this sensor has got damaged, the set won't respond to any remote control handset. The sensor can be located just behind the infrared sensor window at the front panel of the TV. To access it, you have to open the TV. It is a three terminal component, will be soldered diretily to front panel circuit board, of with the main baord itslef. Will look somewhat brownish black in colour. There are so many types can be seen . Just look what type if fitted with your TV.
2_4_2012_6_58_45_am.jpg2_4_2012_6_59_07_am.jpg2_4_2012_6_59_34_am.jpgSee some models infrared sensors. Check out which type your TV has.2_4_2012_7_00_45_am.jpg
Top Sharp Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
