Question about Panasonic Lumix Cameras
My Panasonic Lumix ZS50 has a system error on he focus I can not adjust and lens is all the ay out and tells me to turn off and turn back on but same error code comes on-system error(focus)
6ya staff
SOURCE:
Ty Price
  • 11967 Answers
SOURCE: Panasonic Lumix DMC FX 33 wont focus and shows
Fixing a Lens Error on a Digital Camera
This has to be THE most common failure mode for a digital camera. Some common error messages that might show up on the LCD's of cameras with this problem include “E18 lens error”, or “lens error, restart camera”. Some cameras might show nothing at all, but merely make a beeping noise as the lens goes out, then in, then the camera shuts off. Sometimes the lens won't even move.
The problem is actually quite common throughout all camera brands. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended. Believe it or not, one BIG contributor to lens errors is using a camera case. Sand, gunk, case fibers, etc... accumulate at the bottom of the case. These materials love to cling to the camera by electrostatic build-up from the camera rubbing against the side of the case (especially those cases with soft fibrous intreriors). Once these materials work their way into the lens mechanism, that's all she wrote. I have many Canon's, and NEVER use a case for this very reason.
A camera owner that suffers this problem may have no recourse for having the camera repaired. Many camera makers will not honor repairing this problem under warranty as they claim it is due to impact damage to the camera, or sand or debris getting into the lens gearing mechanism (neither of which is covered under warranty). The quoted repair cost is usually close to or more than what the camera is actually worth.
Fortunately, about half the cameras that suffer this failure can easily be fixed by one of the following methods. None of these methods involve opening the camera, although some have potential to cause other damage to the camera if excessively done. If the camera is still under warranty, before trying any of these, please please first contact your camera's maker to see if they'll cover the repair, or to determine how much they'll charge for the repair. Who knows, you might get lucky. But if they quote you a number that's higher than the value of your camera, you may want to consider the following methods.
The methods are listed in the order of risk of damaging your camera. Thus make sure you try them in the listed order. And remember, these fixes (especially #6 and 7) should only be considered for a camera that's out of warranty, who's cost of repair would be excessive, and would otherwise be considered for disposal if unrepaired:
Fix #1: Remove the batteries from the camera, wait a few minutes. Put a fresh set of batteries back in (preferably rechargeable NiMH 2500mah or better) and turn the camera on. If that didn't work, try pressing and holding the Function or OK button while turning the camera on.
Fix #2: Remove the batteries, then remove the memory card. Then install new batteries, and turn on the camera. If you get an Error E30, it means you don't have a memory card installed, so turn it off, slip in the memory card and turn it on one last time.
Fix #3: Insert the cameras Audio/Video (AV) cable, and turn the camera on. Inserting this cable ensures that the camera's LCD screen remains off during the start process. Thus extra battery power is available to the camera's lens motor during startup. This extra power can be useful in overcoming grit or sand particals that may be jamming the lens. If the AV cable doesn't fix the lens error by itself, consider keeping this cable installed while trying fixes 4, 5, and 7 as a means to provide extra help to these fixes. But note that I DON'T recommend keeping the cable installed during Fix 6 as you may damage the AV port while tapping the camera. Reinsert the cable only AFTER tapping the camera.
Fix #4: Place the camera flat on its back on a table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to autofocus while the lens is extending, hopefully seating the lens barrel guide pins in their slots.
Fix #5: Blow compressed air in the gaps around the lens barrels with the idea of blowing out any sand or grit that may be in there jamming the lens. Other variations include blowing with a hair dryer in “no heat” setting, or sucking the gaps with a vacuum (careful with this one).
Now we're entering into the realm of potentially damaging your camera in conducting the fix. There is definitely some risk here, so take care when conducting the following two fixes.
Fix #6: Repeatedly tap the padded/rubber usb cover on a hard surface with the intent of dislodging any particles that may be jamming the lens. Other variations include hitting a side of the camera against the palm of your hand. A lot of people have reported success with this method. HOWEVER, there is also some potential for damaging or dislodging internal components with this method, such as unseating ribbon cables, or cracking LCD screens.
Fix #7: Try forcing the lens. More people have reported success with this method than with any of the other methods. HOWEVER, there's obviously some potential for damaging your camera by using this method. Variations include gently pulling, rotating, and/or twisting the lens barrel while hitting the power button. Attempt to gently straighten or align the barrel if it's crooked or twisted. Another variation includes looking for uneven gaps around the lens barrel, and then pushing on the side of the lens barrel that has the largest gap (note pushing the lens barrel all the way in is NOT recommended as it may become stuck there). While doing any of the above, listen for a click that indicates that the lens barrel guide pins may have reseated in their guide slots. If you hear this click, immediately stop and try the camera.
Posted on Feb 23, 2010
Nicole Hughes
SOURCE: my Panasonic Lumix DMC-FX150 is giving me a SYSTEM ERROR
I'm not sure if you've gotten this resolved, you probably have - however, others will find this useful. When I left my memory card out the camera worked fine but when I would insert the memory card again, poof: "SYSTEM ERROR (FOCUS)." You can take your memory card to most photo places, even Costco/Walgreens, and ask them to reset your card. It doesn't erase the pictures on there but it does a reset/reboot to the card. Anyhow, I hope this helps. Good luck!
Posted on Aug 04, 2010
lock123
Andrea Lock
  • 6831 Answers
SOURCE: my panasonic lumix DMC-FS15 won't
Hello
The problem is that the lens has become stuck in the barrel. There are some DIY solutions you could try, but the probability is that you will have to get it fixed by a professional.
Use these at own risk as it may further damage the camera.
Firstly , try connecting your ac adapter or usb cable.
Try holding the shutter button while switching on the camera.
Look at the lens , and if some of the lens 'circles' is misaligned or not concentric then try wiggling it (while holding camera lens down).
Try gently pushing or pulling the lens when it extends but this is risky as it may cause the lens barrel to slip out of its guidance system.
Another way to do this is to place the camera lens down on a hard surface and then power it up. Be sure to use a soft cloth or something similar as to not scratch your lens or casing. Let the lens push the camera up and down a few times and sometimes the little resistance provided by the camera is enough to get things going again.
Try hitting your camera near the lens on the body with the soft tissue on the palm of your hand.
Other than that , I would take the camera to a repair center for a evaluation to see if it would cost more to repair than to replace the camera.
If it is still under warranty I would suggest you take it in before trying any of these steps and remove any off-brand batteries or accessories as some stores are really fussy about warranty repairs on camera's with non-brand accessories.
Hope the advise is useful. Please do not hesitate to let me know if you need any further assistance.
Regards
Andrea
Posted on Sep 10, 2010
Ty Price
  • 11967 Answers
SOURCE: Lumix zs3 "system error (focus) Camera
This has to be THE most common failure mode for a digital camera. Some common error messages that might show up on the LCD's of cameras with this problem include "E18 lens error", or "lens error, restart camera". Some cameras might show nothing at all, but merely make a beeping noise as the lens goes out, then in, then the camera shuts off. Sometimes the lens won't even move.
The problem is actually quite common throughout all camera brands. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended. Believe it or not, one BIG contributor to lens errors is using a camera case. Sand, gunk, case fibers, etc... accumulate at the bottom of the case. These materials love to cling to the camera by electrostatic build-up from the camera rubbing against the side of the case (especially those cases with soft fibrous intreriors). Once these materials work their way into the lens mechanism, that's all she wrote. I have many cameras, and NEVER use a case for this very reason.
Fix #5: Blow compressed air in the gaps around the lens barrels with the idea of blowing out any sand or grit that may be in there jamming the lens. Other variations include blowing with a hair dryer in "no heat" setting, or sucking the gaps with a vacuum (careful with this one).
Posted on Jan 18, 2011
Ty Price
  • 11967 Answers
SOURCE: I am getting a system
How new is it?...can you return it? Can you take advantage of the warranty?
You can also try these (carefully)...sometimes they work.
Posted on Mar 31, 2011
Panasonic LUMIX DMC-FH4 is showing system eror focus. How solve it ?
Can you tell exactly what is on the screen please. The system error focus is not supposed to be an real error that is displayed on your camera.
"System error" is possible. But if switching of and a few moments later switching on does not change the error on the dis[lay, you should contact a Panasonic certified repair centre.
May 24, 2014 | Panasonic Lumix DMC-FH4 Digital Camera -...
System error focus
you hve probably damaged the lens unit. impact while the unit was extended? the auto power off will retract the lens thus damaging the little plastic gears in the lens unit. you may need to replace the lens unit
Dec 18, 2013 | Panasonic Lumix Dmc-fh1 12 1 Mp Digital...
My Panasonic TZ25 says "System Error - Focus". What should I do?
Panasonic DMC TZ25 compact camera - System Error (Focus)
- Try holding the shutter button while switching on the camera (suggested by Andrea Lock, above). I actually had to try this several times as camera was refusing to reset properly, but after a few goes, lens retracted and camera began to work again. Thanks Andrea.
Feb 21, 2013 | Panasonic Lumix DMC-TZ25 Digital Camera...
Lumix DMC-ZR1
This is a lens mechanism fault. USe can of air and spray on surrounding the lens For cleaning the dust. and then try.
Aug 05, 2012 | Panasonic Lumix DMC-FZ28 Digital Camera
The focus on my lumix is getting stuck out, and wont return back into place when I turn the camera off. The camera says there is a system error
Hello - This is going to be a 'hard' fix -- the zoom/focus has a motor which slides the lens in/out.
If that is stuck only a qualified repair person can replace/fix. - It's the only moving part of the camera. Ray
Feb 27, 2011 | Panasonic Cameras
Panasonic DMC-FX35 error message
Sounds as if it has either received a knock, or foreign matter (grit etc) has got into the lens mechanism.
May 30, 2017 | Panasonic Lumix DMC-FX35S Digital Camera
Lumix FS-15 "System error (focus)"
I have the same issue with my 3 month old Lumix DMC FS15 plus it won't focus and gives the error message to "turn camera off and then on" This doesn't fix it.
Bottom line fix: Don't buy this camera again and don't recommend other buy it.
Sep 19, 2009 | Panasonic Lumix DMC-FZ28 Digital Camera
Camera focus error
there is a small logic circuit that controls the motor that retracts the lens and a sensor that tells it the lens is retracted, it is a lens position sensor, one of these two components is most likely defective, the thing is there are no consumer service info provided by panasonic, they will not sell you parts either, the camera is a mystery to take apart and repair without the tech manual which u can't get, so u see the delima here, u must either have this camera fixed by a panasonic repair station or see if it qualifies for a upgrade exchange program for a newer model.
Aug 07, 2009 | Panasonic Lumix DMC-FZ28 Digital Camera
Cameras Logo
151 people viewed this question
Top Panasonic Cameras Experts
Ekse
Tom Chichester
Are you a Panasonic Camera Expert? Answer questions, earn points and help others
