Health & Beauty Logo
M
Majed Posted on Jul 12, 2019
I need the SM for B Braun Perfusor Basic - Braun Health & Beauty
Benjamin McCurdy
Level 1:
New Friend:
  • Contributor 3 Answers
  • Posted on Jul 12, 2019
Benjamin McCurdy
Contributor
Level 1:
New Friend:
Answers
Questions
Helped
464
Points
10
Https://www.manualslib.com/manual/1177527/Braun-Perfusor-Space.html?page=2#manual
How to replace battery for oral braun electric tooth brush
The basic method is:
  1. Dismantle handle.
  2. Desolder old battery and other connections from PCB.
  3. Remove charging coil, pressure warning light, pressure switch, PCB and battery.
  4. Replace battery.
  5. Reassemble PCB and other parts.
  6. Solder in connections for parts and new battery.
  7. Reassemble handle.
https://toothbrushbattery.com/guides/braun-oral-b-professional-care-1000-battery-replacement/
Braun Type: 4259 Food Processor,switch locked in OFF. Without lid of switch,runs on II-speed.Top-screw needs Braun screwdriver to dislodge the unit for inspection and replacement. What to do?
The oddball Mercedes Benz emblem screw heads can be removed by a tamperproof bit. I bought a kit with various versions of these, and by filing the tip to a basic Phillips-like point, the screws came out.
There are 2; 1 under the little corner flap, the other under the pry-off green knob.
Then the top assembly gives access to the switches regarding low, high and pulse.
1helpful
2answers
The screen on my braun shaver has holes and needs replacement can i get new ones for it? its the one that says caution for use only with braun series 549 class 2 power unit www.braun.com it has a trimmer...
Braun 8985 replacement foil and blades is braun series 5 combi 51S foil and cutter replacement pack.
But costomer reviews in amazon.com who take braun series 3 combi 30B foil and cutter replacement pack is fits to Braun 8985 perfectly, very smooth and close shave. Shaves much better than the Braun 51S screens foil.
You consideration
http://www.amazon.com/gp/community-content-search/results/?ie=UTF8&search-alias=community-reviews&tag=best-electric-razors-20&Go.x=0&linkCode=ur2&query=braun%208985&camp=1789&Go.y=0&creative=9325&idx.asin=B001VH6F9G
1st and 2nd gear doesn't work. Can it be fixed and if so how?
Yes it can most likely be fixed. Please see the solution for this problem that has already been covered here http://www.fixya.com/support/t3875766-braun_multimix_280_will_only_operate
You will need a soldering iron and some basic electronics skills to do this repair.
Regards
Toolpower
I cannot click the top on when i try to charge it ....
The latch on the 'arm' of the clean and charging base is broken. You can either change out the top portion of the clean/charge base or replace the whole thing if you don't thisnk you can do the repair.
Both itemsare available at shaveroutlet.com. See links below. Basic instructions for installing the top part are included on the item page
http://shaveroutlet.com/shaver-replacement-parts/braun-7000-series-syncro-clean-charge-base-replacement-part-p-118.html
http://shaveroutlet.com/shaver-replacement-parts/braun-7000-series-syncro-clean-charge-base-p-122.html
B braun syringe pump perfusor compact showing error 063 plese give me answer
B braun syringe pump perfusor compact showing error 063 plese give me answer( what is amalfunction part )
Need Braun coffee maker KF152 12 cup
Do you still need a Braun coffee maker KF152?
Top Braun Health & Beauty Experts
shaveroutlet.com
shaveroutlet.com
ZJ Limited
ZJ Limited
Are you a Braun Health and Beauty Expert? Answer questions, earn points and help others
