Question about Maytag Dryers
I need instructions on how to assemble rollers and parts forE2L maytag
2 Suggested Answers
6ya staff
SOURCE:
MicrowaveSvc
William Miller
  • 9179 Answers
SOURCE: i need to replace my maytag mmv5000 microwave door assembly
Normally you have to separate the door panels (as shown in the attached photo) and then you'll see the previously hidden screws you need to remove.
Or you can watch a YouTube video (not a video I made) that demonstrates how it's done.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
Posted on Sep 26, 2008
Does a kenmoore 80 series have glides
http://www.searspartsdirect.com/partsdirect/part-model/Maytag-Parts/Dryer-Parts/Model-PYE2300AYW/3048/0151200?pathTaken=&prst=0&shdMod=PYE2300AYW
go here and you can see the parts in your dryer,if the model isn't a maytag pye2300ay then just put your model number in there and it will show you,kenmore doesn't make anything,you go by the model number if it starts with 110. it's a whirlpool,if say 417. it's frigidaire made but the maytag model you sent has rollers and i would say if you have a kenmore 80 series it has rollers,you can buy a kit that comes with the rollers,belt and belt pulley
Nov 14, 2013 | Maytag PYE2300AY Electric Dryer
Maytag dryer makes loud squeeling noise when it gets hot. Drys clothes but makes such a loud squeeling noise. Have to let it cool down to continue to dry.
Hi and welcome to FixYa, I am Kelly.
A loud squeal is usually caused by either an idler pulley bearing. a drum roller bearing or a loose belt.
Since you did not include a model number I have to respond with generic across the board information. Idler pulleys, drum rollers and belts for Maytags can be found on this link:
(Just past half way down the page) http://www.apwapplianceparts.com/Laundry+Appliance+Parts/Dryer+Appliance+Parts+/Dryer+Drive+Belts+Idler+Pulleys+and+Support+Rollers/default.aspx
You can enter your model number on this page and find your parts: (Choose model number)
http://www.appliancepartspros.com
If you do repair it yourself.... do yourself a HUGE favor and either take a picture of the belt routing or draw a belt routing diagram BEFORE dis-assembly.
Thanks for choosing FixYa,
Kelly
Jun 08, 2011 | Maytag Dryers
Screaming sound when dryer is on
Hi, W/D here.
Screaming dryers can usually be traced to the drum support roller and the roller shaft. Once the screaming has commenced, both parts usually are damaged beyond reuse. Check this link; it will give you a good idea of what you need, and what to look for. You can scroll over the diagram to view the parts and assembly instructions. A lot of information, if you need it. It will be best to use tha diagrams as a disassembly guide, and confirm that the roller and roller shaft is the issue. Since you're already down to the rollers, it would be wisest to change them both at the same time, if this is the issue.
http://www.searspartsdirect.com/partsdirect/part-model/Maytag-Parts/Dryer-Parts/Model-MDE5500AYQ/3048/0151200/M0606011/00004?blt=06&prst=&shdMod=
Best regards, --W/D--
Feb 18, 2011 | Maytag Neptune MDE5500AY Electric Dryer
I just replaced the belt and rear rollers on my Maytag PYG2300AWW gas dryer, as well as oiled the idler assembly. I was a little concerned because looking in towards the inside, the right roller seemed...
all that's left is the belt pulley and the front glides,if you change out the belt pulley and it still does this it could be the motor but most likely it will be the pulley
Jul 12, 2017 | Maytag MDE9316 Dryer
A clunking noise when running and the dryer still dries
The noise you hear is from a worn bearing that is centered in the belts roller bearing for the be;t tensioner. Sears can get you the replacement parts since they sell these models. they will come as a kit with a belt and the roller assembly with the bearing
Mar 27, 2010 | Maytag Neptune MDE5500AY Electric Dryer
Dryer squeals closer to end of cycles
Hello.
It will either be a drum roller or the belt tension pulley. Most dryers sell there parts seperately but Whirlpool sells a kit that has the rollers, pulley and the belt with a decent instruction sheet on how to do it. If you go to www.sears.com and click parts direct, there will be a place to enter your model number and get ahold of the parts you need.
Jul 22, 2009 | Dryers
Maytag gas dryer squealing
Hi, this is a belt issue. make sure the tension on the belt/motor is sufficient. adjust to specs. if the belt is fine, this will be bad bearings in the roller assembly.
Replace the rollers in this case.
May 21, 2009 | Maytag Dryers
Rollers on racks continue to break, Maytag fix is buy entire new assembly like part number 99003585 wihich is 32.95 each time
I found an engineer who has made stainless steel axels for the rack...www.fifengr.com/maytag/....a cost of $40...but well worth the one time solution....
Aug 22, 2008 | Dishwashers
I need a "Bearing Assembly" for roller brush 61445-1,I Have a GE 106575
Probably should just go to a repair shop and they should be able to order one for you, that is if they are available by themselfs. Or if you have a store where you live that sells vacuum parts, you could go there.
Dec 08, 2007 | GE 106585 Upright Vacuum
Dryers Logo
71 people viewed this question
Top Maytag Dryers Experts
Marvin
Marvin
Archie Ferrarini
Archie Ferrarini
Gerry Harvey
Gerry Harvey
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
