When you double click the Printer and Faxes icon in the Control Panel
you will see the printer that your computer is currently using. See....
if the printer image is clear it is online and ready to use, if its
blurred then its in offline mode and cannot be use.
To correct
offline printer.. some possible reasons is on the usb cable.. check if
there is no open wire along the cable...Inserting the USB connector on
the other usb slot of the cpu sometimes work just wait first until it
is read.
If the printer is still blurred and offline after
checking the usb connection, the 2nd thing to do is check the
properties of the printer if it is set to offline mode. how? Double
click your printer icon. It will display the print jobs window. Click
on the Printer tab and uncheck on the "Use printer Offline". Cancel all
pending print jobs, close the printer window and try again to print.
When you double click the Printer and Faxes icon in the Control Panel you will see the printer that your computer is currently using. See.... if the printer image is clear it is online and ready to use, if its blurred then its in offline mode and cannot be use.
To correct offline printer.. some possible reasons is on the usb cable.. check if there is no open wire along the cable...Inserting the USB connector on the other usb slot of the cpu sometimes work just wait first until it is read.
If the printer is still blurred and offline after checking the usb connection, the 2nd thing to do is check the properties of the printer if it is set to offline mode. how? Double click your printer icon. It will display the print jobs window. Click on the Printer tab and uncheck on the "Use printer Offline". Cancel all pending print jobs, close the printer window and try again to print.
Several printers are connected to my Dell and sometimes without paying attention I forget which printer I'm using. On your print set up page scroll down until to your printer and select it. If you have only one printer, then select it as your default printer.
go to start menu select printers and faxes or go to control panel, select printers and faxes, open and select your printer right click and scroll down to use printer offline and click it will work, dont forget to rank me when it works thanks
hi friend this is very common problem for f300 series PSC
just delete the printer from printers and faxes and reboot the machine it will install printer again
there is funny thing abt this series it is saying offline when powered on and connected but when you disconnect iit will say "offline-use printer offline"
hi iam kishan from india
do one thing if u have a driver cd of your priner
disconnect printer and go to control panel clik on add/remove program remove all driver oand sofftware of your printer
and restart ypur pc and after restarting insert cd in install software of your printer
do no connect printer untill computer want
or connect after finnish i
