Question about Bosch Washing Machines
BOSCH washer pedestal NOT SLIDING OUT Smoothly
Remove pedestal from washer
Those washers are heavy! They have weights in them to prevent moving when spinning. Some use bolts through the bottom of the pedestal up through the washer and others use bolts down through the washer into the pedestal. Remove the bolts and lift the washer off the pedestal. You might need to get levelling bolts for the washer or check to see if the bolts are on the bottom of the pedestal. Make sure you get help to move the machine.
Jan 13, 2016 | LG WM2487H Front Load Washer
How do you install whirlpool duet pedestal
Make sure that you get the pedestal designed for your washer. The white pedestal for the GHW9400P would be LAB2700MQ. (There are slight differences in the pedestals for different series washers. The holes in the base of the washer will not line up with the holes in the pedestal for a mismatched combination.)
First if your washer has been installed, uninstall it. You need to turn off the water. Then disconnect the power cord and (carefully) the fill hoses. Loosen the hoses first and then completely remove them. Drain the hoses into a bucket. Disconnect the drain hose from the back of the washer. Use pliers to squeeze the clamp to get the drain hose loose.
Pull the washer away from the wall. Cover the area behind the washer with cardboard and tip the washer onto its back (on the cardboard).
Pull out the drawer of the pedestal. Next snap the spacers into the holes on the top of the pedestal. (These are part of the hardware kit in the drawer of the pedestal.) Remove the shipping spacers from the front of the pedestal (behind the drawer). Remove the Philips head screw from the drawer slides and pull the drawer completely out (save the screws). Push the slides back into the pedestal.
Look at the washer and remove the feet if present. Partially install two of the hex head screws from the pedestal installation kit in the bottom holes of the washer. (These are at the center back of the washer if it is standing up.) Leave the screws about 3/8" from the bottom of the washer. Move the pedestal over to the washer and slide the keyhole openings of the pedestal over the two partially installed screws. Position the pedestal against the top of the washer and insert the remaining two hex head screws. Do not tighten completely.
Align the pedestal with the base of the washer on all sides. When it is lined up, tighten the 4 screws by reaching through the drawer opening of the pedestal. Bring the washer and pedestal back upright. Reinstall the washer (remove the packaging if this was a new install). Level (front to back and side to side) the washer using the pedestal feet (again reach through the drawer opening). Make sure that all 4 feet touch the floor. Tighten all 4 locknuts.
Pull out the drawer slides and reinstall the drawer. Reinstall the Philips screws. Close the drawer.
For pictures of the install, go to the Whirlpool support site http://www.whirlpool.com/owner_center . Search for your pedestal and get the installation manual. The direct link for the LAB2700MQ0 install is http://www.kitchenaid.ca/assets/pdfs/literature/Installation%20Instructions%20-%208537141.pdf .
I hope this helps.
Aug 04, 2011 | Whirlpool GHW9400 Duet Washer
This is a Bosch WVD24520GB washer dryer
what was question ??????????????????????????????????
Sep 20, 2010 | Bosch 15 White Washer And Dryer Pedestal...
Wm2277hw is leaking water from the bottom... does not appear to be coming from a hose at the back. The washer is on a pedestal and water was dripping into the drawer, was wet between the washer and the...
Easiest start is to take the top off and check for leaks maybe using a flashlight. Top comes off by removing a couple of screws in back, the sliding it rearward about 3 inches and then lifting up. Good luck. Report back what you find. Use comments.
Jan 25, 2018 | LG WM-2277HW Front Load Washer
Pedestal for Samsung washer & dryer, will other brands fit too?
Just bought a red Samsung washer/dryer, looking for pedestals, but don't want to buy $200.00 ea., any suggestions
May 07, 2010 | Samsung WE356A5W Washer/Dryer Laundry...
Installing pedestal to washer
You want to level just the pedestal in the place where you will be using it so when you put it in position mounted together later it is done. Also very easy to do first. Get the pedestal level, tighten the lock nuts, put the washer on its back. Usually you remove the washer feet, take the pedestal drawer out, screw on each side, bolt the pedestal to the washer with the four screws provided. Tip pedestal and washer up, on to something that slides easily to protect floor. There usually are some type of shipping bolts that have to be removed from back of washer before using on new units. Usually four and these have to be removed.
Jan 13, 2010 | Maytag EPIC MFW9700S Front Load Washer
How do we install the pedestal to the front load Kenmore washer
The pedestals bolt into the bottom of the washer where the legs where.
This is definatly a heavy job, so it's best to get 2 more people to help you out.
#1 Remove all 4 legs that came on the washer factory.
#2 Make sure you have enough room to manouver the machines. The washer is going to be the most difficult so start with it.
#3 Have your friends tilt the machine back and you slide the pedestal under the machine.
#4 Kneel down infront of the machine to prevent it from sliding forward.
#5 Have your friends lift up the back of the machine and walk it forward until the holes in the top of the pedestal are in line wiht the holes from where the legs where.
#6 Thread in the bolts and tighten.
**You will need to take out the drawer of the pedestal to get the back bolts in. There are plastic clips on the inside of the runners, just push those down at hte same time and pull the drawer**
Good luck! Please let me know if this was helpful!
Oct 03, 2009 | Kenmore 15.5 in. Pedestal
Vibration
Does it have runner pads on the leveling feet on the washer resting on the pedestal?
If so, and it still moves all over, you will have to fasten the washer to the pedestal with bolts and nuts. I had a GE that did the same thing. I finally laid them on their side, drilled out the holes to fit bolts and washers I bought from Home Depot. They really don't make that clear, do they?
Sirwriter
May 06, 2009 | Bosch Nexxt 500 WFMC3301 Front Load Washer
Kenmore pedestal for the front loading elite washer and dryer
some pedistals have a screw on drawer just behind front on end of rail newer ones have a small black lever on each side ..pull drawer completely out lever is about midway at end of inner rail pull lever 1 up other down drawer will pull off rail reinstall by sliding rails back together and pusing all the way in
Jun 10, 2008 | Kenmore 15.5 in. Pedestal
Out of balance spinning.
there is a spring that hooks to the back the tub of the washer and conects to the frame of the washer its there as a counter balance. if that spring was not put back in place the washer will shake like crazy. if that spring is conected the basket is warped
Nov 17, 2007 | Bosch Nexxt Premium WFMC6400UC Front Load...
Washing Machines Logo
Top Bosch Washing Machines Experts
Marvin
Marvin
peter gittos
peter gittos
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
