LG Tromm WM2075CW will not spin. I've done several loads of laundry and with the last load it started up as usual, but then gave the LE error. I took the towels out and there's water in the drum that will not drain. I tried to run it through a cycle with nothing in there - but I keep getting the same error code and the water is not draining. HELP!
Check first if repositioning the drain hose would help solve the problem. If your unit employs a drain valve, have it checked out. It has a solenoid or a small motor that opens and closes the part. Check as well the drain pump if it is running or no power is being supplied. Have the wire checked to see if there are loose connections.
