Question about Westinghouse SK-32H540S 32 in. LCD TV
Westinghouse SK-32H540S screen goes dark
I have a Westinghouse LCD TV SK-32H540S, 1 year old. When I turn it on, the screen works for about 5 seconds, then goes dark. The sound continues. The screen goes dark despite what's being displayed: tv shows, menus, whatever, so it's clearly the screen, not the source of the image. Any idea what might be the problem, and how to fix this?
6ya staff
SOURCE:
Anonymous
SOURCE: Westinghouse SK-32H540S LCD TV Turns Itself On - Appears Random
turn the timer off.
Posted on Jan 27, 2009
westytech
vidal chavez
  • 120 Answers
SOURCE: Westinghouse SK 32H540S Turn on TV, get
Hello, it sounds like you need to replace the inverter board, I believe this model has LIPS board which is the power board and the inverter board put in to one single board. You can find price and availability for parts by emailing parts@wde.com.
Posted on Feb 03, 2010
westytech
vidal chavez
  • 120 Answers
SOURCE: Westinghouse sk-32h540s TV, VGA input, image can't center.
Hello, two things, one try using the TV with the native resolution of 1366 X 768, and secondly try updating your video card. If you are not having this issue with the TV on the other inputs than most likely it is a settings issue with the laptop. Please rate this comment if it was helpful.
Posted on Apr 07, 2010
Foxfire1600
  • 3 Answers
SOURCE: Westinghouse SK 32H540S when i Turn on TV, get
The problem is cause by the transformer on LIPS inverter (Power supply + Inverter board). You could see an obvious burn on the 1 of these transformers ( There are total 3 black transformer on this board). The part number is 4302H. It is available online at http://www.lcdparts.net/TransformerDetail3D.aspx?ProductID=2775
Posted on Jun 12, 2010
SOURCE: Westinghouse LCD TV SK-32H540S, 1
1 swollen Capacitors / Replace
2 blown Diodes on inverter board / on some # 508 or 908
3 bad transistors in inverter bad will appear overheated powdery coat
4 replace inverter if you cannot locate problem on it
there is a safety built into the high power back light supply and that is if too much current is drawn or light is shorted it will not burn up
or hazard high volt shock to user.
capacitors and diodes driven with power transistors
look for darkened spots on the board to identify hot transistors
puffy tops and leaky bottoms of capacitors
when you turn it on does the bottom or top of the screen show image a Milli second before the other it should be evenly the lag
is the one requiring more amperage
Posted on Aug 07, 2010
My Westinghouse SK-32H540S pictures shuts off after 10 seconds. the sound stays on but no picture. is it the troubleshoot? i tried unpluging everything and repluging it and still the same thing happens...
This problems are the tv 1 or 2 long LCD inverter boards are dead.These 1 or 2 long LCD inverter boards provide the tv LCD screen pannel a backlight to produce a picture.Tries websites like Shopjimmy.com,Ebay.com to buy those refurbishes 1 or 2 long LCD inverter boards for the replacement.
Mar 24, 2011 | Westinghouse SK-32H540S 32 in. LCD TV
My westinghouse 32 inch flat panel tv turns on i get the picture then in about 20 seconds picture goes out but still have volume. i turn it off then on again and the same thing happens ....help
This tv have a dead long board call the LCD inverter board.This long LCD inverter board job are to help the LCD screen panel to have a backlight to produced a picture.Replaced this long LCD inverter board,will solved this problems.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish long LCD inverter board for the replacement.
Dec 02, 2010 | Westinghouse SK-32H540S 32 in. LCD TV
My Westinghouse SK-32H540S TV comes on for about 5-10 seconds, then the picture goes off. The sound continues.
You need to replaced your Inverter Board, If you can do the job, get the Board Part number and order it from Westinghouse. If not call a Professional TV Technician. At least you have an idea what's the trouble with your set. Hope this Tip will help you.Thanks
Aug 12, 2010 | Westinghouse SK-32H540S 32 in. LCD TV
Westinghouse LCD TV SK-32H540S, 1 year old. When I turn it on, the screen works for about 5 seconds, then goes dark; power is on - sound still works but no picture
Aug 07, 2010 | Westinghouse SK-32H540S 32 in. LCD TV
Westinghouse SK-32H540S LCD HDTV Video Comes On,
Take a strong light and put it up against the screen. Do you see a faint image? if yes, then your backlight has failed. Could be a lamp, inverter or power supply issue. Not for DIY'ers.
Apr 23, 2010 | Sharp Aquos LC-37G4U 37 in. HD-Ready LCD...
Apr 06, 2010 | Westinghouse SK-32H540S 32 in. LCD TV
TV Turns on picture comes on for 30 seconds then picture goes off and sound stays on. Even after leaving tv on the sound stays but the picture does not come back on. Its a westinghouse SK-32H540S
This is not the fix for this TV. I guarantee that none of the capacitors exhibit the common bulging characteristics of a faulty capacitor. The common answers to everyone's questions are to replace the capacitors. Most likely the culprit is the inverter board.
Feb 26, 2010 | Westinghouse SK-32H540S 32 in. LCD TV
Westinghouse SK-32H540S 32 in. LCD TV Logo
170 people viewed this question
Top Westinghouse Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Westinghouse Televison and Video Expert? Answer questions, earn points and help others
