My Asko W6441 front load washer constantly gets an F3 error message which the manual shows is a problem with the drain pump. I have checked the hose for flow issues and there are no blockages or kinks. This usually occurs during the rinse/spin cycles. Can anyone help?!? I saw a previous post about this being an issue with the door lock but the manual says it is an error due to the drain pump. Help!
Hello. You said that you checked the drain line for obstructions, but did you check the pump? I would remove the hoses from the pump and using a flashlight, look into the suction port on the pump. Check the pump for any obstructions (like the occasional stray sock) and check the pump impellers. Look for broken/missing blades and ensure that the impeller spins freely. If there are missing/broken blades or if you cannot get the impeller to spin freely, the pump is defective. You may have already done this, and if so I apologize. Anyway, hope this helped and best wishes.
