Question about Hitachi Televison & Video
Hello i have hitachi 50hyt62u . Where are the power buttons located? I do not have the small scroll button on the left side behind the tv.
Anonymous
SOURCE:
Anonymous
  • 95 Answers
SOURCE: locked tv
What is the make and model number of your flat screen tv.
Posted on Mar 11, 2008
Anonymous
SOURCE: TV makes chirping sound and power button blinks, T.V. does not turn on
It is the lamp, you have to change the lamp, it's in the left side of the tv, have a litter compartiment, opened and take out two screw and take out the change and change it. you have to buy a new one. go to google.com and put the model of the tv and find the price of the lamp.
Posted on Jun 25, 2008
Crankstart
Chris
  • 696 Answers
SOURCE: Automatic scroll does not work on touchpad unless you hold down the left click button
This can be set to scroll for you as it is a simple setting in the mouse control panel.
Go to your start menu and open Control panel, select classic view in the top left corner if there are less than 20 icons(pictures) in the menu. Now double click on the mouse icon. Click on the advanced tab. then select your synaptec device in the list and click the properties button below.
There are several options on the menu, one will say "Virtual Scrolling"
Check the box beside Vertical Scrollong and then click OK on this window and the mouse window.
Close the control panel and you're on your way.
I hope this helps Fixya,
Chris
Posted on May 19, 2009
Anonymous
SOURCE: Vizio LCD DTV 32 inch. Model L32. I can't 'scan'
Follow up on No DTV tuner after unplugging it a month for vacation. After I let it set plugged in for about 2-3 days it started working normally again and has been fine ever since. I hope this may help someone else. Genez 6-7-09
Posted on Jun 08, 2009
Anonymous
  • 65 Answers
SOURCE: Hitachi projection TV does not power up
You probably have a blown 2kV capacitor and 2 amp fuse. Look for signs of black burning inside.
Posted on Aug 09, 2009
I need a code for my Hitachi 50HYT62U tv for virgin tivo remote
2610,2663,2681. If you wish to get more; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. One among it has general set-up codes to check with TVs and other devices are given, in the order of the 'device's brand name list' in alphabetical order. Pull up older posts. Search the sites by type in the brand name to your device in its search box at the top right part of the display window. It will help you to find the document easily.
http://remotesearch.blogspot.com/
http://electrohelponline.blogspot.com/
Dec 28, 2014 | Hitachi Televison & Video
I have a Hitachi 50"
Hello mark riazzi,
I am not sure what you mean by a box that came with the tv. What is the model of your number of your tv? Some tv's have power right at the front of the tv and the other buttons are usually located on the side of the tv or if its a thin tv, then on the back at the edges. You should have also gotten a remote with the tv if it was new out of the box. If not, get a universal remote. The manual that comes with the universal remote will have a code for the model of your Hitachi tv. Follow the instructions and you can use that remote instead. Good luck.
-Joe
Aug 29, 2011 | Televison & Video
I have a Hitachi 42" plasma/ 42HDT51 and the power
Replace your buffer boards they are two unit located on the right of the plasma if you are looking the plasma from behind. Do you have any sound?
Thanks,
Nov 21, 2010 | Hitachi 42HDT51 42 in. Plasma SLC1551AW
Hitachi 43UWX10B - LED Light on constantly on will not go off
Power relay is defective. All contacts are not opening when power is removed. Located on small power supply board, upper rt side.
s 901 part# FJ00142 should be under $10, do a google search with part number and 50 sources will appear.
easyab
s901, FJ00142
Jul 14, 2010 | Hitachi 43UWX10B 43" Rear Projection...
When I turn on the TV the blue indicator light comes on but there is no display, then the blue light starts blinking.
The following steps should be able to correct the problem:
1) Unplug the TV or remove AC power from the TV
2) Count to ten and then plug in the TV
3) Locate the [Menu], [VOL-] and [Power] button on the TV’s side panel
4) Using the buttons on the TV’s Side Panel, press and hold both the [Menu] and [VOL-] buttons.
5) While holding those buttons, press and release the [Power] button one time and count to 3 before releasing the [Menu] and [VOL-] buttons.
6) The TV’s lower left Blue Power LED will come ON.
7) Wait 30 seconds. Confirm that the blue LED on the Lower Left of the TV (not the iPod dock for iPod models) has remained ON during this time.
8) Press the [Mute] button on the TV remote twice
9) Unplug the TV or remove AC power
10) Count to ten and plug the TV in
11) The TV power should automatically come ON and the blue power LED with be ON
12) Wait 40 seconds and the TV picture should appear
13) You can now continue using your TV.
14) If the picture does not appear, power on the TV manually:
· If the LED begins flashing, unplug and power ON a second time.
· If the LED begins flashing again, power ON the TV without unplugging
If the LED begins flashing again, contact us directly by phone to obtain a local authorized service center for you.
If the TV does power on, please reply back with the software version number for us to research this issue. Please follow these steps to obtain the software version number:
1) Press the [Menu] button on the remote control.
2) Using the arrow keys in the center of the remote, scroll over to the "settings" menu and select the [OK] button on the remote
3) Scroll down to "system info" and select [OK] button on the remote
Dec 19, 2009 | JVC Televison & Video
Cannot find the adjustments for convergence behind the control panel a described. not able to bring up the crosshairs to ajust convergence as described in many replys. help 53uwx10ba model
Your tv may have a small button hidden on the board. You will need to look behind the speaker panel at the circuit board. Its a small blue button located on the convergence board.
Sep 12, 2009 | Hitachi 53UWX10B 53" Rear Projection...
Change from TV mode to AV mode for a Hitachi C28W4110SN
There should be buttons somewhere on the TV itself to switch input modes. Look around where the power button is located and see if there is a menu button you can access. Then use channel up/down and volume up/down to scroll thru modes to find input
Hope this helps
TankMurdock
Apr 27, 2009 | Hitachi 61SDX01B 61" Rear Projection...
No power to my Hitachi 42Pd6600 plasma tv
the master switch at the bottome of the TV per Brianbuy solved my problem...Thank you!
Jan 20, 2009 | Hitachi 42PD6600 42 in. HD-Ready Plasma...
Hitachi 53FDX20B
Good Day;
Take off grill, take off panel, on left side on front of circuits you will see a small switch. Push button. Remember to save data after adjustments are done via TV's remote.
Good Luck!
Jun 02, 2008 | Hitachi 53UWX10B 53" Rear Projection...
Televison & Video Logo
41 people viewed this question
Top Hitachi Televison & Video Experts
matt martin
matt martin
Todd Hill
Todd Hill
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
