Hi! You can do such conversion in any operating system. All you need is browser with internet and this tool https://pdf4me.com/ as you can see there are many different possibilities. Just choose what you need to do and upload your files!
Try Softaken PDF Champ is a more efficient pdf to images conversion application, which is able to migrate pdf to jpg format with original output quality and fast conversion speed. Moreover, PDF to image Converter is also can easy-to-use software, just simple several clicks can guide users to the friendly interface and finish pdf to image conversion quickly.
Two ways
put pdf on screen
then use snipping tool to screen capture
https://support.microsoft.com/en-us/help/13776/windows-use-snipping-tool-to-capture-screenshots
2nd method
put pdf on screen
keyboard right top look for Print screen key
May need to press Alt or CTRL Key then Print Screen key
This places screen capture onto clip board
Open Pc Paint
Select Paste or CTRL Key & - V Key together
Then Save file
You can Crop image in Pc Paint
SOURCE: Convert PDF to PDB
There is an E-Reader package you can download for free called Stanza, all you do is open the file you wish to convert (can be anyformat) with stanza and then export it into the file you wish
SOURCE: How can I convert Samsung
first, transfer the Npf File from your phone to a computer system. Then download a npf file converter from the internet. Once you have successfully downloaded the Npf file converter, use it to convert the npf file into Doc or PDF.
Good luck.
SOURCE: I can't convert printmaster files
Hello. 1. In Tools/Options/General Options, check the box beside "Optimal Printing Resolution". 2. Go to File/Printer Setup/Printer Setup. 3. Under "Name" select Broderbund PDF Converter v2.10d 4. Next, go to File/Professional Printing. 5. Select "Save As PDF". 6. At the next screen, type the name of the PDF file you want to save in "Project Name". 7. Under "PDF Resolution", select 600 dpi. 8. Click on "Save As". In the next window, browse to the folder in which you want to save the file (for example: My Documents). 9. Click on the "Save" button. 10. PrintMaster will save the PDF file to the folder you selected. 11. Open the file in Adobe Acrobat to make sure all the elements and pages are there and that it looks as expected. 12. Once you are satisfied, upload this file to Print Pelican. There are two caveats: 1. Because it is made to print cards and calendars to your laser or ink-jet printer, PrintMaster expects page sizes to be standard ones such as 11" x 17" or 8.5" x 11". Custom page sizes (such as 7" x 10") may not work properly. 2. Do not use backgrounds or elements that print to the edge of the page. This is a feature that will not print properly from PrintMaster. Make sure your pages have white margins with nothing printing on them. If this doesn
Here are the steps:
SOURCE: I am trying to convert
ZDL files are proprietary, there is no software to convert them since Avery doesn't allow it. But you can convert it in another way. You will need the oficial Avery printing software and a virtual printer one.
Start by installing the virtual printer
http://www.softpedia.com/get/Office-tools/PDF/PrimoPDF.shtml
Then install the printing program
http://www.avery.com/avery/en_us/Templates-&-Software/Software/Avery-DesignPro-for-PC.htm
Now launch the printing program, select the zdf file you want to convert, click print and instead of selecting your actual printer select the Primo virtual one - it will deliver a pdf of the original zdl.
SOURCE: REadiris won't convert pdf to word
you can try this free online pdf to word converter to convert pdf to word online.
