SMC Barricade g SMC2804WBRP-G Wireless Router Logo
Posted on Aug 29, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
WPA enable SMC Barricade
I've entered passphrase, saved settings, what next? router still not "locked"
Anonymous
Level 2:
  • Expert 184 Answers
  • Posted on Aug 29, 2009
Anonymous
Expert
Level 2:
Answers
184
Questions
0
Helped
85053
Points
554
Turn on wireless, then WEP encryption, then add passphrase.
How do I secure?
WIRELESS To configure the Router as a wireless access point for wireless clients (either stationary or roaming), all you need to do is define the radio channel, the Service Set identifier (SSID), and security options.ADVANCED SETUP 47 Channel and SSID You must specify a common radio channel and SSID (Service Set ID) to be used by the Router and all of your wireless clients. Be sure you configure all of your clients to the same values. SSID: The Service Set ID. This should be set to the same value as the other wireless devices in your network. SSID Broadcast: Broadcasting the SSID on the wireless network for easy connection with client PCs. For security reasons, you should disable SSID broadcast. (Default: Enable) Note: The SSID is case sensitive and can consist of up to 32 alphanumeric characters. Wireless Mode: Set the communication mode for the Router. Default: Mixed (11b+11g)Configuring the Wireless Barricade g Router 48 Transmission Rate: Set the rate of data transmitted from the Router. The lower the data rate, the longer the transmission distance. (Default: Fully Automatic.) Channel: The radio channel through which the Router communicates with PCs in its BSS. (Default: 6) Note: The available channel settings are limited by local regulations. g Nitro: In a crowded 2.4 MHz frequency, the connection speed is much lower than the promised 54 Mbps. The g Nitro implemented by Intersil's Prism Nitro technology dramatically enhances your wireless network speeds. It provides up to 50% more throughput in 11g only environment, and improves network throughput by 3 times in mixed mode.ADVANCED SETUP 49 Security If you are transmitting sensitive data across radio channels, you should enable wireless security. Configuring the Wireless Barricade g Router 50 WEP Wired Equivalent Privacy (WEP) encryption requires you to use the same set of encryption/decryption keys for the Router and all of your wireless clients. WEP mode: You can choose disabled, 64-bit or 128-bit encryption. Key Provisioning: Select a key type of static key or dynamic key. Static WEP Key Setting You may manually enter the keys or automatically generate encryption keys. To manually configure the keys, enter 10 digits for each 64-bit key, or enter 26 digits for the single 128-bit key. (A hexadecimal digit is a number or letter in the range 0-9 or A-F.) For automatic 64-bit security, check the box of Passphrase, enter a passphrase and click SAVE SETTINGS. ADVANCED SETUP 51 Four keys will be generated. Choose a key ID (1-4) from the drop-down list or accept the default key. If you use encryption, configure the same keys used for the Router on each of your wireless clients. Note that Wired Equivalent Privacy (WEP) protects data transmitted between wireless nodes, but does not protect any transmissions over your wired network or over the Internet. WPA Wi-Fi Protected Access (WPA) combines Temporal Key Integrity Protocol (TKIP) and 802.1x mechanisms. It provides dynamic key encryption and 802.1x authentication service. With TKIP, WPA uses 48-bit initialization vectors, calculates an 8-byte message integrity code, and generates an encryption key periodically. For authentication, it allows you to use 802.1x authentication for an environment with a RADIUS server installed on your network. Selecting the Pre-shared Key enables WPA to use the pre-shared key in a SOHO network.Configuring the Wireless Barricade g Router 52 Field Default Parameter Description Cypher suite TKIP One of the security mechanism used by WPA for frame body and CRC frame encryption Authentication 802.1X Select the authentication mode. • 802.1X: It is for an enterprise network with a RADIUS server installed. • Pre-shared Key: It is for a SOHO network without any authentication server installed. Pre-shared key type Passphrase (8~63 characters) Select the key type as in pass-phrase or in 64-Hex characters Pre-shared Key none Specify in pass-phrase style or in 64-Hex characters. Group Key Re_Keying Disable The period of renewing broadcast/ multicast keyADVANCED SETUP 53 802.1X Management access will be checked against the authentication database stored on the Router. If an authentication RADIUS server is used, you must specify the secret key of the Message-Authenticator attribute, i.e., Message Digest-5 (MD5), and the corresponding parameters in the RADIUS Server Parameters field for the remote authentication protocol.Configuring the Wireless Barricade g Router 54 • General Parameters • RADIUS Server Parameters Field Default Parameter Description Enable 802.1X Yes Starts using 802.1x security control. Session Idle Timeout 300 seconds Defines a maximum period of time for which the connection is maintained during inactivity. Re-Authentication Period 3600 seconds Defines a maximum period of time for which the RADIUS server will dynamically re-assign a session key to a connected client station. Quiet Period 60 seconds Defines a maximum period of time for which the Router will wait between failed authentications. Server Type RADIUS Selects the authentication server type. Field Defaults Description Server IP 192.168.1.1 The IP address of the RADIUS server. Server Port 1812 UDP port is used for RADIUS authentication messages. Secret Key none Defines a text string on both the RADIUS client and server to secure RADIUS traffic. The RADIUS server requires MD5 Message-Authenticator attribute for all access request messages. The 802.1x authentication scheme is supported by using the Extensible Authentication Protocol (EAP) over the RADIUS server. NAS-ID none Defines the request identifier of the Network Access Server
Source: http://www.smc.com/files/AK/2804WBRP-G_MN.pdf
Please leave feedback for this answer, thanks.
4helpful
2answers
How can I find or reset the security key on my D-link WBR-2310 wireless router?
In order to find the wireless security password of your Dlink wireless router G WBR-2310 , please follow these setps
1. Open up the internet explorer in the computer in which you are online and clear the address bar and type in the number 192.168.0.1 and hit enter.
2. You will be logged into the D-Link router setup page .
3. Under the SETUP tab, in the left hand side, click on WIRELESS SETTINGS? you will find Wireless security Mode under which you can find the password for the wireless settings.
Good Luck!
Thanks in Advance!
With Regards,
Prema.
How do I set up password protection for my SMC Barricade Turbo 2404WBR Router?
Please follow the steps mentioned below and check if the issue is resolved.
  • Please open a new browser window and in the address bar type in 'http://192.168.2.1' or 'http://192.168.2.1:80' or 'http://192.168.2.1:88' and press enter.
  • The password would be either blank or smcadmin.
  • To enable Encryption or Secure the Wireless Network, follow these steps:In the router's configuration page: Click on Advanced Setup -> Wireless -> Encryption.
  • Select the Encryption type (WEP, WPA, WPA2 etc), type the Security Key and save the settings.(128-bit encryption uses 26 characters. Example: 01 2C 45 67 89 A0 CD EF 01 23 45 6D F9
    64-bit encryption uses 10 characters. Example:
    01 A3 45 F7 8)
  • The Wireless/Internet is Secured Now.
  • You can also set the password for the Router log in: Please click on Administrator settings and input the new password.
Good Luck!
Thank you for contacting.
11helpful
3answers
How do I find my wpa2 key on D-Link DIR-655?
  1. If Donna's method didn't work you can try this. Just an additional thing.
  2. First of all you have to Open your Browser
  3. Type http://192.168.0.1 (or use the NetBIOS name http://dlinkrouter)
  4. Log in.
  5. In the router setup page click on wireless settings
    then click on Wireless Security. It has to be there. Check under the Advanced Tab if its not there. You will be able to Enable/Disable WPA/WPA2 with PSK. Check whether you can see it there (the Key).
  6. If it allows you to re configure you have to go through the Setup partially again (look below). If it doesn't allow and you can't remember the key, you have to Reset the Router and go through the Full Setup.
  7. Here is how:
  8. Under the Wireless settings Wizard, Click on "Launch Wireless Security Setup Wizard".
  9. Click "Next".
  10. Enter the SSID which is the Name of your Wireless Network (Case Sensitive).
  11. Choose the Level of Security. Click "Next".
  12. If you have chosen "Best" or "Better", enter a key which is 8-63 long. If you selected "Good", enter 13 Characters or 26 HEX Digits. Please Write it down.
  13. Click Next. If you have chosen "Best" or "Better" you will be shown the key in the next Window.
  14. If you plan to use WPA-PSK encryption, you can configure that as well.
  15. Next to Security Mode, select WPA-Personal.
  16. Next to WPA Mode, select Auto, WPA2 Only, or WPA Only. Use Auto if you have wireless clients using both WPA and WPA2.
  17. Next to Group Key Update Interval, enter the amount of time before the group key used for broadcast and multicast data is changed (3600 is default).
  18. Next to Pre-Shared Key, enter a key (passphrase). The key is entered as a pass-phrase in ASCII format at both ends of the wireless connection. The pass-phrase must be between 8-63 characters.
  19. Click Save Settings to save your settings. If you are configuring the router with a wireless adapter, you will lose connectivity until you enable WPA-PSK on your adapter and enter the same passphrase as you did on the router.
Barricade 7004VWBR Wireless Router: how can I configure my router to secure wirelee co...
You need to log into the wireless router either by a computer that successfully connects wirelessly or by physically connecting with an ethernet cable. Once connected, log into the router by open a web browser (Internet Explorer, Mozilla Firefox, Google Chrome, Apple Safari), and typing the router's address (usually 192.168.1.1 or 192.168.0.1) into the Address (or URL) line. The default usernameand password is usually "admin" & "admin" or "admin" & "password". Once successfully logged in, look for a tab or link that says "Wireless" or "Security". You'll be able to change whether security is enabled or disabled, and the password associated with it. Your security options are WEP or WPA (or WPA-PSK). WPA-PSK is the most secure, but WEP is also an acceptable choice. Select the security option of your choice and either enter text into the passphrase generator or choose your own password and type it into one of the security key text fields. If you use a password that is not a plain english combination of letters and numbers, be sure to write it down so that you can enter it as needed on other wireless devices that need to access your router (ie-pda phones, game consoles, laptops, desktops, etc). Be sure to save changes so that the security settings and password is saved.
Let me know how you make out.
How to secure and setup a password for my SMC barricade G smc2804wbr router using a toshiba labtop. I do not have the intallation CD drive. please help
1helpful
SMC2804WBR-G Cannot connect Wireless
Have you checked the encryption type, and verified that you have set aes or tkip correctly to match your router? That would be my first guess.
My second guess is that you have mistyped your passphrase or have a trailing space in one place and not in the other or a capital letter and a small letter or some other typo. Can any computers or phones connect to the wi-fi with wpa on? You could try WEP, even though it is laughably weak, since the key is in hex and not therefore misinterpretable, just to see whether any encryption will work.
But my first guess is encryption type (assuming that it is not detecting it, like my cellphone and PS/3 do).
I am trying to configure my wireless router for wpa-personal wireless security
It is recommended to enable encryption on your wireless router before your wireless network adapters. Please establish wireless connectivity before enabling encryption. Your wireless signal may degrade when enabling encryption due to the added overhead. Before you start make sure your computer is directly connected to your router.
1- open a browser and on the address box type the following and press enter ---> http://192.168.0.1
2- on the next screen you will be asked for your routers username and password in order to login. If you have'nt change this information before you can use the following (click log in after)
Username : admin
Password: password
3- once you are in, on the left side menu click on
WIRELESS SETTINGS
4- on the next screen you will see below
WIRELESS SECURITY MODE:
Security Mode:-___________________
Next to Security Mode, select Enable WPA-Personal Security
5- a new menu appears below and asks for the following:
Next to Cipher Mode select--->Auto.
Next to Personal/Enterprise select---> Personal.
Next to Passphrase, enter a key (passphrase). The key is an
alpha-numeric password between 8 and 63 characters long. The password can include symbols (!?*&_) and spaces. Make sure you enter this key exactly the same on all other wireless clients.
Enter the passphrase again next to Confirmed Passphrase.
6- Click Save Settings to save your settings. If you are configuring the router with a wireless adapter, you will lose connectivity until you enable WPA-PSK (or WPA2-PSK) on your adapter and enter the same passphrase as you did on the router.
If you have further questions please do not hesitate to ask me...Good Luck!!!
Cant put a lcok on my smc router
Manual for WBR14-G2 router [6.2 MB] in pdf format:
http://www.smc.com/files/AG/MN_SMCWBR14-G2.pdf
Keeping others from connecting to your router:
1. Have an "wired only" router login access or for this router "change and disable your SSID". This way you avoid that others can login to
to the router changing your settings: See page 48 of the manual.
1.1 Wireless Network Name (SSID): change the default name SMC
to "any private name" ( and remember for later login )
1.2 Broadcast Wireless Network Name: change from default ENABLE
to DISABLE .
2. Make a secure wireless encryption key for your connection:
see page 87.
2.1 For most secure key select WPA / WPA2 only and SAVE SETTINGS .
2.2 See page 91 for entering and saving your secure key: the password
that must be entered to get access to the router.
I need to secure my router. I had payed to have it set up when I was getting my computer fixed only to find out that my son could log on with out a password. How can I fix this.
To set up wireless router security, there are four main steps, which are the same for most routers. These are:
1) Login to your router, using a wired connection
2) Change the router login password
3) Change the network name (SSID)
4) Enable WPA encryption.
************DETAILS************
1) Login to your router, using a wired (Ethernet) connection.
Make sure you have a cabled connection to your router. Then open a web browser, and type the router’s IP address into the address bar. For example, this is http://192.168.0.1
If you log in successfully, you should then see the router configuration screen.
2) Change the router login password.
To change the router password, find a menu option such as Setup, Tools, Administration, Basic Settings, Management, or Utilities.
Set and confirm a new login password. Click ‘Save/Apply’ when finished.
3) Change the SSID (network name):
The SSID or Network Name is the name you see when you are looking for an ‘available wireless network’.
To access this setting, find a menu option such as Wireless, Wireless Security, Security, or perhaps Advanced Settings.
Change the SSID from the default, to anything you like. It is case sensitive, and you can use up to 32 letters – but do not use something that could identify you, or your location. Click ‘Save’ or ‘Apply’ when finished.
Find the Wireless Security or Wireless Encryption Options section - often in the same section as the SSID (eg for Netgear – it’s still in Wireless Settings).
You may have a number of encryption options. Select WPA-PSK or WPA2-PSK (good choices to start with).
You then need to enter a network key. The box to enter this may be labelled Network Key: it may also be labelled WPA-PSK, WPA Shared Key, PSK, Security key, Passphrase, Pre-shared key, Authentication key .
Note down your network key carefully. You will need this to connect wirelessly. Click ‘Apply/Save’ when finished.
That's it - you have done enough to secure your network, and can close the screen.
Top SMC Computers & Internet Experts
ExpressFiX
ExpressFiX
Grand Canyon Tech
Grand Canyon Tech
Are you a SMC Computer and Internet Expert? Answer questions, earn points and help others
