Question about LG Heat cool Window Air Conditioner
Excessive Leak My new LG unit has an excessive amount of water leaking from the drain... When I put the drain plug in it stops of course, but I''m worried that water will just collect inside the unit if I leave it like that.  What could be the problem? Is there a problem? Any help would be much appreciated.
  • LG Master
  • 4,656 Answers
Remove the plug and tilt the AC slightly downward on the outside so the water will flow outside where it is supposed to go. Thanks, Sea Breeze
Posted on Aug 29, 2009
6ya staff
SOURCE:
My LG dishwasher when I turn it on it drains the water, then it fills it up with water, about 1 min. later gives me the code E1 and drains the water again...
LG Dishwasher Displaying Fault Code E1 LDF7810BB/01 LEAKAGE ERROR // Excessive pump motor RPM due to water leakage
The manufacturer has assigned this error or fault code to indicate that when the drain pump is running it is not experiencing the back pressure it expects. This is usually an indication that there is a water leak in the drain system. Check all hoses and connections. Check under the dishwasher for any major leak. If all checks out, be certain there is a proper loop in the drain hose to prevent siphoning. Finally, if the problem persists, the drain pump itself might be defective.
Sep 25, 2015 | LG Dishwashers
Lg wm-3470hva
Sounds like the drain pump itself is defective
Nov 07, 2017 | LG Washing Machines
My frost free freezer has had a small puddle of water under the front right corner several times now. I unplugged it and let it defrost completely thinking that would stop the problem but it hasn't. Can...
There is a chance the water is coming from the drip tray and or the drain hose to the tray.
when the unit goes into a defrost cycle it is leaking from one of those places check and make sure the hose is in the drip pan correctly and that the pan is also mounted properly and level.
If there is is a lot of water in the pan you may need to check the door seals on you unit and make sure they are sealing properly.
If there is an air leak then the unit could have excessive ice build up and also be defrosting more than usual amounts of water.
Jan 02, 2011 | Frigidaire 20.3 Cu. Ft. Frost-Free Upright...
Excessive amounts of water is leaking into my front passenger seat
if green or orange in color you have a heater core leak. If its stagnant water it is from a plugged up drain tube in the evaporators core housing
Sep 02, 2010 | 1995 Jeep Grand Cherokee
Soleus A/C unit is leaking water out of drain plug
it is working well, possibly has a bad sensor to tell you it's full but put a permanent drain on, run it in the sink or dump it more often. just means it's pulling out excessive amounts of moisture
If you need further help, reach me via phone at https://www.6ya.com/expert/thomas_092728000e6acb79
Nov 03, 2017 | Soleus KY-34 Portable Air Conditioner
Water accumulates at the bottom of the freezer unit and leaks
You must clear the drain of anything that would cause water to pool up after each defrost cycle. Check your door gaskets for wear. Air entering the ice box can cause excessive frost.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Jul 06, 2009 | Refrigerators
LG DISHWASHER WORKS BUT VERY NOISY MODLE:LD-2040WH
The main water pump on this model does not last long. The water seal between pump and motor starts to leak that result in the adjacent motor bearing corroding and eventually failing, resulting in excessive noise. Later the water leak becomes so bad that it triggers the "E I" water leakage display and prevents it from completing the program. The pump and motor is sold as one unit and the whole unit must be replaced. I have tried to replace the faulty bearing and repacked the rubber seal with silicon grease but with no success. If anyone have repaired the water seal successfully please let us know.
Jun 15, 2008 | LG 24 in. LD-12BW5 Free-standing...
Leak problem
Ours did same thing after nearly same amount of time.
Run a couple of sanitary cycles without any cloths.
Only use HE detergent.
Problem stopped after this
Oct 08, 2007 | LG WM1815CS Front Load Washer
LG Heat cool Window Air Conditioner Logo
146 people viewed this question
Top LG Heating & Cooling Experts
Felizardo Erilla
Felizardo Erilla
Steve F
Bill Long
Are you a LG Heating and Cooling Expert? Answer questions, earn points and help others
