SOURCE: Unit Runs (fan and condenser) but no water?
By condenser I assume you mean the compressor is running. Is there ice forming on the front coil?
SOURCE: Water drips from evaporator fan channel Frigidaire FRT17G4B
It sounds as if this is a top mounted refrigerator. (freezer on top) If this is the case, check to see if you need to defrost the drain. You could also have a problem with the door seals. Remember the air coming out of the vent is freezer temp minus a few degrees. It could be that the moisture is condensing in that area.
SOURCE: ac does not blow cold at idle... ac condenser fan
that seems to be the problem. If the fan does not turn on when the a/c is turned on it could be a fuse, relay, control box, or just a bad fan. Try connecting the fan directly to see if it works. Does this car have 2 fans? normally all the small cars have 2 fans one for the engine cooling and one to assist the first when the a/c is turned on. Without the fan pulling air through the a/c condensor the had pressure goes up high enough to shut off the a/c compressor. It also causes some cars to run warmer than usual when stopped. Check the a/c condensor for blockage also which doesn't have anything to do with your fan not working.
SOURCE: How do I clear the AC condensate drain on my 2008 CX-9?
Hello... It is possible that the condensation drain tube for the AC could be disconnected. This just happens sometime.This in turn allows condensation to settle in the AC Module and drip into the passenger compartment.
I recommend taking the vehicle to a mechanic for repairs...
Good Luck... Hope this helps...
SOURCE: 2001 Nissan Xterra Ac condenser Fan not getting
suspect relay. there will be a relay in fuse for ac fan. usually there are several relays of the same type in the fuse box. look for numbers on the relay to be the same then pull them and switch to see if the relay way bad.if so get a new one. if still nothing make sure no obstruction to fan blade. if no then suspect fan motor. get 12v to fan to see. fans are held in by two bolts on top and they just set in holder so remove the two screws and unplug the power cord and you can lift it right out of the vehicle. then get 12v to the motor contacts and see if it is ok. good luck
