Question about Frigidaire Washing Machines
Front Load Washing Machine Frigidaire eurodesign, code E70
2 Suggested Answers
6ya staff
SOURCE:
prem mathew
  • 1294 Answers
SOURCE: Frigidaire washing machine model LTF2940E
Check your outlet filters, clean out. The machine will not spin if the filter is blocked. Also check your inlet into the machine. Clean screens on both ends of the pipes. Refit carefully.
Posted on Nov 30, 2007
What dose E70 mean
Means if it is Kenmore that the cold water is not entering the machine. Try removing the washer hoses from the shut off valves after shutting them off of course. and check the little metal screens on the back of each hose connection check for dirt inside Hot and cold.
Apr 05, 2012 | Frigidaire ATF6000ES Front Load Washer
Washes starts buzzing and blinking and says e70
The e70 error code comes on when the hot and cold water hoses are reversed or not properly installed.
Feb 21, 2011 | Frigidaire Affinity ATF7000E Front Load...
What does E70 means? My washing machine have this after it started for a few seconds.
hi,
The main cause for this e70 error is that the hoses would have swapped (hot to cold, cold to hot). It means the washer isn't getting cold water.Try to switch between the hoses. Another possibility is the faucets are not turned on.
Hope this solution will fix your problem for sure.
Thank You !!
May 29, 2010 | Frigidaire GLTF2940ES Front Load Washer
KEEP GETTING E70 MESSAGE
Are you sure its a E70? If so, the hot and cold lines are reversed.
Apr 25, 2010 | Frigidaire GLTF2940ES Front Load Washer
Code e70 on gltf2940es
The hot and cold water hoses are connected backwards on the back of the machine. Turn off the water faucets Unscrew the hoses Replace the hot with cold and cold with hot
Apr 17, 2010 | Frigidaire GLTF2940ES Front Load Washer
E70
HI, this is a major control board fault code. the chip set on this board is damaged. it cannot be repair and, it is recommended to replace the entire control board(main) in this case.
A service call is recommended.
Jun 17, 2009 | Frigidaire ATF6000ES Front Load Washer
I have a fridgdaire front loading washing machine and the code e70 keeps coming up and the whole system will shut down what does this mean???
You are going to need to download the Factory Service Manual for your Washer. This is a General Code, not specific to anything, You need to run the machine through it's diagnostics to determine the service code that is stored.
Once you get the service code you can narrow down and identify the issue.
Here is the Repair Manual Download Link
Thanks
Jan 06, 2009 | Frigidaire ATF6000ES Front Load Washer
Error Code E70
water fill problem ,,,check fill hose for kink,,,or lost of water pressure,,,you may need to clean inlet vavle screens..onthejob
Dec 20, 2008 | Frigidaire Affinity ATF7000E Front Load...
Nov 30, 2007 | Frigidaire GLTF2940ES Front Load Washer
E70
All w/machines have a maximum load capacity. Look for yours in the users'manual. Overloading could give you problems, bearings, etc. Your machine cld even have a half load switch.
Mar 26, 2007 | Frigidaire GLTF2940ES Front Load Washer
Washing Machines Logo
Top Frigidaire Washing Machines Experts
Gerry Harvey
Gerry Harvey
J. Bradshaw
jimorris77
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
