Question about Yamaha Music
I turned my Yamaha clavinova CVP 96 on today and instead of the white screen I have a lot of blue vertical lines and no sound coming
  • 4 Answers
Hi
the blue screen with lines is normally as a result of the ribbon cable which has contacts on failing.
The remedy is normally to replace the simple the screen assembly the parts for this are around £300 but there would be significant labour to add to this.
i would suggest talking to a local Yamaha technician
Becketts Music Ltd
Posted on Sep 17, 2019
6ya staff
SOURCE:
Anonymous
SOURCE: Yamaha YPG625 screen shows only vertical lines
I brought the keyboard into a local service technician. He told me that he had to remove about 50 screws but the solution was simple. He unplugged and reconnected the ribbon connector. It apparently was not making good contact.
Posted on Oct 21, 2008
Anonymous
  • 12 Answers
SOURCE: Yamaha CVP-401
the back light is maybe to hot and it not good no more well one side it not
Posted on Aug 11, 2009
Anonymous
SOURCE: Yamaha Clavinova CVP-83S NO SOUND OUTPUT
clavinova 83s...comes on but goes off within 20 sec.,sometimes comes on display lights up but no sound or functions?
Posted on Feb 23, 2010
Joe Hogan
  • 10865 Answers
SOURCE: Yamaha Clavinova CVP 55 -
Hello. Most likely you will need to either clean the drive or replace it.
Posted on Sep 21, 2010
standuncan
SOURCE: Can I replace the pedal unit to the Yamaha Clavinova CVP-75?
I can't solve the problem, but just wanted to sympathize because I have the same problem. My pedal is broken on my Yamaha Clavinova cvp85a. It worked wonderfully for years but finally it broke.
I'd be in the market for buying a new pedal or fixing the old one. But I've not found any suggestions in any of these forums for either solution.
Posted on Feb 27, 2011
Does the base detach from the Yamaha CVP-601 for transportation
The Yamaha CVP-601 can be transported fully assembled. However, yes, it can be disassembled if desired.
Your owners/operators manual will detail the procedure.
Click here if you do not have one: Yamaha Clavinova CVP 601 Owner Manual Assembly Preparation Before...
Feb 12, 2018 | Yamaha Music
I need to replace the ped unit on a Yamaha Clavinova cvp 96. It's noisy.
You could try the following which was issued as a service note by Yamaha
Dec 14, 2015 | Yamaha Music
Wiring diagram yamaha cvp 303 clavinova
i have a broken cvp-85a but the pedals are ok so?
Jan 14, 2013 | Music
Need manual for CVP-700 english version
how opening yamaha cvp-700
Jun 30, 2012 | Music
I need a replacement board XE771 for my yamaha clavinova cvp-20
406-582-5849 if you want to talk about it. I have one here and I'm repairing it. Maybe if yours has part of the upper surface intact I can figure out how to fix mine from yours and fix yours at the same time and test it here
Apr 28, 2012 | Yamaha Full-Size Keyboard
Yamaha clavinova cvp-83s
Hi, did you manage to sort your problem as the same thing has happened to my clavinova (same model). Thanks.
Oct 05, 2009 | Yamaha Full-Size Keyboard
Jul 21, 2009 | Yamaha Music
Apr 01, 2009 | Yamaha Full-Size Keyboard
Keys stick on Clavinova CLP 360
A contact rubber for CVP-35, part number VS549800 will work, that's how I fixed my sensor problems on my CLP-360.
Jan 19, 2009 | Yamaha Full-Size Keyboard
Music Logo
71 people viewed this question
Top Yamaha Music Experts
Michial Gueffroy
Mike
Are you a Yamaha Music Expert? Answer questions, earn points and help others
