Frigidaire FMV156DC Microwave Oven Logo
Posted on Aug 29, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Does not cook,everthing else works. fuse?
Anonymous
Level 3:
  • Master 574 Answers
  • Posted on Aug 29, 2009
Anonymous
Master
Level 3:
Answers
574
Questions
0
Helped
219328
Points
1748
Could be a blown fuse in the HV transformer,Could be a defective thermal fuse, Which is all on the inside of the microwave. Be very careful if you try this repair very high voltage present
Lights and exhaust fan not working. Inside light and everthing else works On ge model jvm1190wy 02
I regularly repair these for this problem for $54.95, which includes insured return shipping.
Feel free to contact me via my site. Please include FULL model number*, FCC ID number*, + detailed symptom information. ( * on the tag in cooking cavity or around door frame or control frame or on back)
William E. Miller, AS-EET
http://www.microwavecontrol.com
Microwave Oven Control Panel Repair Nationwide
"Recycling by repairing since 1982"
1helpful
My oven is working but the item inside is not heating. If I put 2 minutes, the oven wprks for 2 minutes, but the item inside is as it is without slight heating
It's very likely the high voltage fuse has blown, often because there's a fault in the cook section, or the fuse has metal fatigue. It will be in a thick plastic tube near the transformer and cook capacitor. Turn the oven off and unplug it for 10 mins, then take the cover off. As a precaution, short out the cook capacitor with a screwdriver. The capacitor is near the transformer, usually an oval shaped can. If it's not fuse fatigue, it can be: faulty capacitor (unlikely); faulty protection diode across capacitor, if there is one (very likely, must be replaced same way round as original); faulty rectifier diode from capacitor to chassis (less likely) or a magnetron heater that is leaky to chassis. All these things need to be disconnected, and tested one by one with a 500V insulation tester, because an ohmmeter will often not show faults in high voltage parts. Any leakage at 2200V will blow a fuse. If there's no high voltage fuse, it will blow the mains fuse inside, then nothing will work, but it's not that with yours, since it partly works. The oven can run without the high voltage fuse, just replace it with a wire with nice thick insulation, or with some plastic tubing over it. Anything else that's faulty must be replaced. I get my parts from WES Components at Ashfield in Sydney. Microwave parts in the cook section have high voltage ratings, and must be replaced with at least equal rating components. I just fixed a Samsung microwave with its high voltage cook fuse blown. The rest was ok, so I'd say the fuse wire inside had metal fatigue. I also always put a drop of light oil on both ends of the fan shaft, it runs quieter and faster then.
If the fault happened suddenly, it will be one of the above faults. If the oven is very old, it will have a gradually increasing cook time, as the magnetron wears out. If the cooking time is too long, replace the magnetron, they're only held in with 4 screws or nuts. It must be the same physical fit and at least the same power rating as the oven's rated output power.
Kenmore microwave model 721.80033700 won't heat
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Basic Microwave Oven Troubleshooting Tips
heatman101
Microwave want heat any longer. Everthing else is
HI. in most cases, this will lead to a failed Heating device(magnetron tube).It would be wise to check the Magnetron cutoff fuse to be sure of its integrity. if the fuse is blown, simply replace it. if the fuse continues to show continuity, replace the magnetron.
(((The fuse is located inside the unit along side the magnetron)))
Microwave lights up but no cook!
Magnetron of your Microwave oven may be defective. If there is a fuse between the highvoltage transformer and to the highvoltahe capacitor check the fuse is blown off. If so replace the fuse. If it is Ok change the Magnetron.
3helpful
Emerson microwave, #MW8119SB, push start button to start cooking
Replace the fuse with a ceramic fuse from Home depot! costs less than $3 and it will fix the problem. I had all the same problems as everyone else, you name it my microwave had it! you must remember replace it with a ceramic fuse! not a glass one. I know people say its the switchboard and all that nonsence but I promise you, the fuse plays a majoe roll in the microwave not working properly. Even though it doesnt look broken, a junky fuse can cause your appliance to do very strange things. I replaced mine 6 months ago and it works like its fresh out of the box.
Top Frigidaire Microwave Ovens Experts
ZJ Limited
ZJ Limited
Paul Bade
Jerry Naidoo
Are you a Frigidaire Microwave Oven Expert? Answer questions, earn points and help others
