I Have a samsung RF265ABBP french doors bottom freezer. Icemaker will go thru cycle after holding test button for 8 seconds but won't fill tray .used hair dryer to defrost water inlet, made one tray of ice and quit working freezer temp set at -1. any ideas
Was the inlet tube frozen. If so your water inlet valve on the back where the water supply comes in is probably leaking and when the water reaches the freezer it freezes, blocking the inlet tube. Replace the water inlet valve.
You can Try swapping the wires on the dual water inlet valve. Then
try the water dispenser. The water should go to the ice maker. This will tell
you weather or not the ice maker valve is working and if the line is clear.
