Hi, check your compressor and thermostat, your compressor is short/cycling, cutting off to soon/quick. check compressor capacitor for short, could also be leak in a/c system, check refrigerant/freon. or compressor has a hard start, you can purchase a compressor hard start kit at appliance store and try to start compressor, but first check thermostat and compressor start/run capacitor. good luck.
Check the timer settings on the control. they may be set to something you may not wish to be set..
SOURCE: I cannot get my wintair room air conditioner to
It sounds like your air conditioner is doing what it is supposed to do. The compressor kicking in and out is an energy saving method of using the ac. When the thermostat (ball attached to evaporator coil) registers the set temperature the compressor kicks off.
Its a window unit..You just set the thermostat where you want it.
