Computers & Internet Logo
Posted on Aug 30, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Sim card slot on my toshiba satellite will not upload pictures
I have a toshiba satellite and the sim card slot will not upload the pictures. i have an SD optima and on the slot it says it takes SD so i know i'm using the right sim card
Anonymous
Level 3:
  • Master 788 Answers
  • Posted on Aug 30, 2009
Anonymous
Master
Level 3:
Answers
788
Questions
0
Helped
253836
Points
2355
Check the card with another computer or using the camorra with card inserted.
This lets us know the card is working and will store information.
If the card checks ok, then go to the Laptop and look in the device manager for flags, while camorra is hooked up and turned on.
If you find flags, remove them and reload drivers.
1helpful
Toshiba satellite c660-2el will it take xD picture card
Yes it is possible. There is a memory card slot, from that you can easily import photos in Windows and then print them to your printer.
2answers
How to insert sim card to motorola A955
sorry to interrupt... Any one can upload the simcard hole?
Mar 20, 2012 • Cell Phones
I want to learn how to upload pictures from my Cannon Powershot A95 to my Laptop - Toshiba Satellite M45 S331. Does the laptop have a built in card reader?
Hi
Does your laptop have a slot on the front or side of it that is the same size as your card
if so insert your card into the slot and see if it comes up with a box giving you the option to view
if it does you can view it with windows explorer then highlight everything you want and either drag it into a folder that you open on you laptop or drag them into your pictures that will be in your documents
or you can highlight them all then right click and send to where ever you choose
if windows does not reconize the card reader then go to the website of the laptop www.toshiba.com and go to support/downloads and search for the card reader driver and download it making sure that you get the right one for your make model and operating system
good luck
also the cannon camera propably has software with it so that you can load it onto the laptop and upload the pictures that way
Where is the slot for the SIM Card?
It has no SIM card slot. It has a Card Bus slot if that is what you are referring to.
Adding memory to Toshiba A75-S211
you buy the memory here for a great price or anywhere online instructions are on the page
it replaces the 512
http://cgi.ebay.com/1GB-DDR-333-for-Toshiba-Satellite-A75-S211-Memory-RAM_W0QQitemZ250353026446QQihZ015QQcategoryZ158897QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
  • Memory Card for Toshiba Satellite A75-S211 Memory RAM- Designed and Optimized
  • Toshiba Satellite A75-S211 Memory RAM Memory Upgrade -Easily installed
  • More Memory Equals - More Speed for your APPS
  • The Toshiba Satellite A75-S211 Memory RAM has a memory card slot or slots, that allows you to add more memory to your Toshiba Satellite A75-S211 Memory RAM, giving you enhanced performance and speed. You will see the Immediate speed increase in your computers performance.
    Stop waiting for programs, and functions to happen, STOP WAITING!!! Start enjoying technology as you should.
    We work directly with our memory card manufacturer to insure perfect compatibility with the Toshiba Satellite A75-S211 Memory RAM. Only using the highest quality memory chipsets for our memory cards, so you are assured compatibility and performance. All of our memory cards are Designed and Optimized for Toshiba Satellite A75-S211 Memory RAM . Technical specialists have personally verified our memory cards compatibility with the Toshiba Satellite A75-S211 Memory RAM.
    Worry Free Installation: Just Follow these Steps Desktop and Laptop instructions below.
    Desktops
    1. Unplug Power cable
    2. Remove Case
    3. Slide memory card in Open slots- the memory card will only fit in one way
    4. Snap the side clips in place
    5. Close Case and Power Up
    6. You are ready to go.
    Laptop
    1. unplug and remove Battery from laptop
    2. Open memory compartment on bottom using Philips screw driver
    3. inset memory in open slot, if no open slot remove current memory by pinching metal clasp on side of memory
    4. Close compartment and power up you are off and running.
    Place for a memory card from digital camera to
    It does not appear that this laptop has a media slot for you to put your memory card into. So you can use the USB cable that came with the camera - but I find that it is always very slow, and uses up the camera's battery pretty quick.
    So you may be better off getting a USB media reader. you'd remove the memory card from the camera, put it into the slot in the reader, and plug the reader into a USB port. In My Computer you'd see a new drive pop up, and you could click on the DCIM folder, and then the 100XXXXX (where XXXXX is the name brand of the camera, or some portion of it) folder, and you can then cut and paste your pictures to the computer. If you Cut instead of Copy, it deletes the pictures from the media, so that when you put it back in the camera, it is blank and ready to take more pics.
    Grand Canyon Tech
    Grand Canyon Tech
