Question about Simpson Washing Machines
My Simpson EZI 5.5 Kg simply wash keeps showing E30 and stops what does this mean and how to fix it?
  • 566 Answers
6ya staff
SOURCE:
Anonymous
SOURCE: Electrolux/Simpson EZI sensor 5.5 kg machine cycles.
Well I'm an idiot. They did say there was a fast wash, but it specified that it was for extra rinses to help people with detergent allergy etc., but did not give a time for the cycle. They should have said it was the short wash for everyone. I tried it, and it was fine. Thanks anyway. If I ever have a real problem, I'll be back.
Posted on Aug 04, 2009
Anonymous
SOURCE: We are using our Electrolux/Simpson Ezi Sensor washing
also have the same machine - if you wash with the eco rinse the clothes will ALWAYS have the soap residue on them and if you use the deep rinse then this machine will just sit there doing the very occasional agitate for up to 6 hours - can't win - have only just hung out a load and as usual there are many many dry spots on the sheets which is a daily occurence - really hate this machine and it's so called u-beaut functions -
Posted on Mar 11, 2010
SOURCE: simpson ezi loader washing machine clicks 3 times
It sounds like a door switch fault see if the end light and the start/pause light are flashing count the flashes if end flashes 4 times and the start/pause once or maybe more this could be error 41, door switch fault.A door switch would cost about $ 20 but there may still be a problem with the main Programmer.
Good luck.
Posted on May 03, 2010
joeF
SOURCE: Simpson ezi sensor 8.0 kg won't spin lid lock flashes and alarms
Hi
To solve the beeping and lid lock light flashing and the machine not doing a spin dry. Do the following.
I have a SIMPSON EZI SENSOR 8Kg top loader. This is what I did.
WARNING HIGH VOLTAGE. switch the power off and unplug the machine.
DO NOT do this if you are not familiar with working with high voltages.
To get access to the lid lock switch,
1. Remove 2 screws at the rear of the washer.
2. Remove 2 screws at the front of the machine located under the lid and covered by small round plastic plugs.
The top cover can now be raised gently from the front.
3. Remove the 2 screws that hold the lid switch.
4. Remove the clear plastic cover from the lid switch.
5. DANGER HIGH VOLTAGE ( Verify that power is off)
6. Find 2 blue wires these go to a magnetic reed switch (25mm long 3mm Diameter).
Cut the blue wires and discard the reed switch. insulate the ends of the blue wires and push them back into the track in different directions so there is no possibility that they can make contact with each other.
7. Find 2 white wires these go to a set of contacts that are mechanically closed by the solenoid.
8. Pull out the contacts and the 2 white wires.
9. Cut the white wires at the contacts, strip 5mm of plastic off the wires and twist them together, The wires will have corrosion, clean them with sand paper, they must make good contact. I recommend that you solder them together.
10. Insulate them and push them back into the track.
11.Reassemble starting with fitting the clear plastic cover.
Your good to go BUT BUT BUT,
WARNING
The Lid safety protecting during the spin dry cycle will no longer function,
So don't do this if you need the safety of the lid closed during the spin cycle.
Remove 2 screws at the back of the machine
Posted on Feb 05, 2012
luisa_sgro
  • 713 Answers
SOURCE: My simpson ezi sensor wont agitate
hi just read your posting.Does the machine spin and drain?Please reply with answer and I can help you further.
Posted on Jul 14, 2012
I have a Simpson EZI set 9.5 just stopped working in the middle of wash, water is still half way. It stopped with no lights flashing or sound
if you put the dial in the middle of any cycle and pull the dial can you hear a faint motor sound? if so its simply a broken belt.
Jun 09, 2018 | Simpson Washing Machines
Hi,i have a Simpson EZI Sensor 6 kg top load it has PU error code, any one knows what this code reflects? Thank you in advance Mike
It means pump error. Water is slow to drain or not draining at all. May be a blockage or could be a faulty pump.
Dec 06, 2016 | Simpson Washing Machines
Hi, i have a simpson 9.5 kg ezi set and it has been going out of balance only on light loads, could you please tell me possable cause thank you
Could be the drum bearing. If it's noisy when operating that could indicate the bearing is deteriorating.
Jul 01, 2016 | Simpson Washing Machines
I have a Simpson ezi Top Loader 8 Kg what does a E20 error code mean
Lift the top by unscrewing the screws in the back or remove the back panel and there you will find a code and test sheet. Very easy to follow if you follow it to a T.
Jan 20, 2016 | Simpson Washing Machines
Simpson ezi 950 9.5 will not empty, rinse, spin dry.
That sounds like the pump is jammed. Have you checked for hair slides or similar? Once the pump is free to operate, your Simpson should resume normal service.
Feb 20, 2014 | Washing Machines
I have a Simpson ezi set 9.5 kg washing machine.It has stopped in the middle of a wash and the LCD screen I showing EFO.Can you tell me what this means and what I need to do to get machine to finish...
i have a 9.5kg simpson washing machine just 5months old and ive had this problem E20 quite frequently that its annoying. I printed out a manual and foundout why. i do not have the patience to remove draining hose im sure there is a simplier way. Ive notice if i tap the side of machine 3 to 5 times it drains lol! seriously never had a problem with my old 7.5kg hoover machine, please help
Jun 19, 2013 | Washing Machines
Simpson washing machine 8kg ezi sensor watter wont stop running
Hi just read read your posting.Is your machine the Simpson Ezi set? If it is and the water keeps running does it at any stage while it is filling start to agitate? Or does the machine keep filling and does not start agitating?Please reply with additional information and I can help you rectify this fault. Looking forward to your reply.
May 16, 2011 | Washing Machines
Aug 03, 2009 | Electrolux Washing Machines
Washing Machines Logo
1,064 people viewed this question
Top Simpson Washing Machines Experts
STEVE
j_woodman
Level 1 Expert
Are you a Simpson Washing Machine Expert? Answer questions, earn points and help others
