SOURCE: steam comes out of dryer after cycle and door is opened
Probably has a restricted vent. Go outside with dryer running and check air coming out vent. Should be a good blast...not just a breath. Clean out the vent and make sure it's not kinked. If it vinyl or foil vent, replace it! Also make sure lint screen is cleaned everytime.
SOURCE: PROBLEM WITH HOTPOINT WASHER DRYER - MODEL BWD
the filter cap is jammed on my hotpoint bwd 129 whats the best way to get it of and clean the filter
SOURCE: I just bought a Whirlpool
It sounds like the solenoid valve for the steam system is hanging open letting water run in to the steam chamber and then right into the drum. Their is either some debris hanging open the valve ,or it's just a defective valve. Your not going to be able to fix this concern without replacing the steam valve assy
PS. this valve works almost exactly like the valve in your refrigerator ice maker water line
SOURCE: My whirlpool duet steam dryer
Hello, Thank You for using FixYa. I will be helping you today.It can be a stuck relay to the water valve or a water valve that is not closing all the way. Put a towel across the bottom of the drum a few hours and see if it gets wet when the unit is not in use if so the valve is stuck open and needs to be replaced.
Thank You and please rate my answer if it was helpful..
