Question about Watts Electrical Supplies
I have a valsi generator 7500 watts with 13.5 robin OHV engine EH41D 1002306 i need a replcement carburetor for it
    Sergeant:
  • 290 Answers
Maybe you can check the operation manual.
diesel generator set at: www.dieselgeneratortech.com
Posted on Oct 16, 2019
6ya staff
SOURCE:
Anonymous
  • 18 Answers
SOURCE: Generator runs, but does not generate electricity
Reset / tickled? There are resistors and diodes in the end of the alternators rotor (the bit in the middle that spins) If these look ok visually then change the capacitor which is a barrel shaped object usually with 4 prongs on the end. Without a capacitor the genset will not produce a voltage.
Posted on Sep 19, 2008
parlapanov
  • 142 Answers
SOURCE: use a 7500 watt transfer switch with a 8000 watt
There is no problem to use it if the load to be transferred is under 7500 W.
Even a load of 8000 W may be handled for a short time, but if the protection of the switch is adjusted at 7500 W (the respective current), it may drop after some time.
Posted on Aug 07, 2010
NOT ME
  • 2841 Answers
SOURCE: The gas tank has rusted
Call 1-866-260-4843 http://www.valsi.com.mx/Default.aspx?lenap=1&olac=2&sedo=3 Hover over Support and then click Service Center or Distributors. You should be able to find a distributor or service center near you. One other option is to just install a fuel tank from another brand that will fit within the area that you have for the fuel tank. You can modify the mounts and secure any fuel tank that fits.
Posted on Sep 08, 2010
bonehead1967
SOURCE: I have a valsi 7500 watt 13 hp with tecumseh
Valsi 7500 watts/13hp tecumsa engine. Was running fine and then started surging like it was going to die and then it ran out of gas. Put fuel in it and now it wont start. Gets fire and has plenty of gas. Problem???
Posted on Apr 08, 2011
George Moore
SOURCE: Can't find a carburetor for a decent generator
What is the carburetor number for a 1600 generator with a Suzuki H120A engine ??
Posted on May 27, 2011
Is there a Auto shut off switch/elect overload that would prevent a Valsi 7500 13hp generator to start?
yes
it is called a low oil warning module and prevents spark if the sump oil level is too low for safe operation
Oct 25, 2017 | Electrical Supplies
I need a new robin subaru thottle body r1100
I believe this generator uses a carburetor.
Try calling Jack's Small Engines during their business hours; I don't see a carburetor listed separately and it may be very expensive.
Robin Subaru R1100 Generator Parts Diagrams
You may be able to just clean the carburetor you have and save a lot. The video isn't the exact engine but it is close.
Feb 08, 2015 | Subaru Cars & Trucks
Homelite LR5550 serges when it runs is there a way to set the governor so will run smooth
Try opening the high speed jet about 1/8 turn. If that don't work clean the carb.
Jul 07, 2014 | Garden
Haven't started it since 6/13/08. Tried for IRENE,went through step by step but pull after pull and no start. In 08 added stabilizer ,but now fuel smells bad. Book says clean carburetor;see engine...
Robin/Subaru post all their engine stuff on their website. If you poke around you should find a PDF owners manual, parts manual, and the service manual. Service manual should have what you need. Definitely drain all the gas, clean spark plug, and change oil as well.
http://robinamerica.com/industrial.aspx
Sep 05, 2011 | Coleman Powermate Subaru 5000W Portable...
I have a valsi 7500 watt 13 hp with tecumseh enduro xl/c engine-its extremely loud and wouldn't stay cranked. My ex - an ''idiot'' worked on it without my knowledge - we now have lines that we don't know...
Jun 23, 2010 | Electrical Supplies
Tappet clearance and spark plug gap on 5.5 hp ohv engine, i have a generator which runs on natural gas made by china i just want to know the gap of tappet and the spark plug gap
I have a Robin but they all are pretty much the same for plug gap and tappets. I worked in a lawnmower small engine repair shop for many years in San Diego
I set them all the same and never had one return. I just did mine a couple of months ago and hand lapped the intake and exhaust valve seats. Starts first time everytime like the 7.5 year old unit is new!!!
Plug gap 0.19
Tappets
Intake .005 cold
Exhaust .006 cold.
Jan 25, 2010 | Watts Onan Portable Generator - 4000 ,...
Sep 18, 2008 | Electrical Supplies
Electrical Supplies Logo
54 people viewed this question
Top Watts Electrical Supplies Experts
Sheldon Dedek
rlev_7
Level 1 Expert
Norman Worley
Are you a Watts Electrical Supply Expert? Answer questions, earn points and help others
