Nice refrig . Is there ice in the icemaker and it just wont dump ? Does the icemaker have no ice or water inside ? Are the coils clean under front of refrig ? Dirty coils can keep the icemaker from dumping , if it contains ice inside . If no water in icemaker , Pour about 1/2 cup of water into icemaker . If it dumps the cubes , replace the water inlet valve ( piece the wall water line connects to on refrig ) . If the icemaker doesn't dump , check the coils . If coils are clean , replace the icemaker . Also , make sure the metal arm on the icemaker is down (up-off , down-on )
Take a 4 inch piece of 14 gauge insulated wire and strip 1 inch of insulation off each end. Bend the wire into a U shape.Remove the plastic cover from the front of the icemaker. Insert the bare ends into the terminals marked T and H on the face of the icemaker. The wheel should move and dispense the ice into the bucket. If it does not move and drop the ice replace the icemaker.
