Is it possible to repair the drain pump in an lg wm3677hw combo washer by replacing the impeller or do you need to replace the whole pump? Do you have a place to recommend online or in LA California to purchase parts for this washer?
You replace the whole drain pump. Pretty easy to do from the opening in the bottom by resting the unit on its back. (Make sure you drain the unit completely) You should be able to get the drain pump (pt #4681EA2001D) from http://www.encompassparts.com/lgconsumer/ for less than $50 + s&h.
