The tape mechanism on my panasonic nv-gs11 fails to engage to allow playback of recorded images. the ' press reset button ' message keeps re - appearing after reset.
This alarm indicates that AN IRREGULARITY IN THE MECHANISM OF THE CAMCORDER HAS BEEN DETECTED.You can solve the problem by hitting the reset button. Resetting procedure is described below.Your feedback would be appreciated.Good Luck.
Panasonic JVC Description F01 No Take-up reel rotation F02 E03 No Supply reel rotation F03 E02 Mechanism has not unloaded to the eject position F04 E01 Mechanism has not fully loaded to the stop position F05 E04 Rotation of video head has stalled or to fast E06 Tape drive motor is not rotating or stalled F31 Data transmission error F51 Focus motor is not functioning, No focus F52 Zoom motor is not functioning, No Zoom U10 Dew sensor has detected condensation or failed U11 Video heads have been detected as dirty or failed Matti Knuutila[email protected]
The same happens from time to time with my panasonic NV-GS11 GC video camera and I have no idea what is causing it. But what I normally do is just turn it of wait 10 seconds and turn it on again. If it stil comes on try removing the tape and see if it is faulty.
I also have the same problem and after almost buying a replacement I thought I would try one time to get it to go.
What I did was start the cam without a tape in it, let it bring up the little red icon indicating no tape inserted, (it hadn't started flashing "PLEASE RE-OPERATE AFTER PUSHING RESET BUTTON" at this stage) then I inserted my tape. Hey presto, it works although for how long I don't know. I'll immediately start burn my tapes to disc while the going is good.
...and try this first...: You need to know in which position was camera turned of. So try turning it on in RECORD OR PLAY position. It will work then...
A similar thing happened to me - I took it to panasonic service centre to fix and unbelievably the problem was that the HAND STRAP was quite tight (I have small hands and set it snug) and prevented the door from openeing just another milimetre more, and thus caused the carriage to 'jam'. Loosening the hand strap and opening the door allowed the tape carriage to move properly again. This was a great relief (although I still had to replace the carriage mechanism a few months later.....due to reset button message)
Dear sir,
Please check right side of the mechnism their will be plasic stud. Clean that stud properly. & check tape inserting side some metal type contacts also clean it will be in right side of the mechanism.
thank u. reply if any problem
use this
http://windv.mourek.cz/
WinDV is a small and easy to use Windows application for capturing videos from DV device (camcorder) into AVI-files and for recording AVI-files into DV device via FireWire (IEEE 1394) interface...."
