Question about Frigidaire FDL45P1 Dehumidifier
Frigidaire Dehumidifier gives F2 error code and no longer runs.
Exactly the same problem as Mr. Cunningham. An F2 error idicates a "bad sensor". Which sensor? Where is it? How do I swap it out?
    New Friend:
  • 3 Answers
F1 is room temperarure sensor error. F2 is tube temperature sensor error.
The room sensor usually is located in the front of the condenser. The tube sensor is usually plugged in a tube near the condensor.
The tube temperature sensor (thermistor) should be about 10K ohms.
Posted on Jan 12, 2013
    New Friend:
  • 3 Answers
ACCORDING TO FACTORY-NO SERVICABLE PARTS AVAILABLE
Posted on Jun 02, 2010
6ya staff
SOURCE:
Why is my soleusair dehumidifier model GL-DEH-50 say F2
Pipe Temperature Sensor Malfunction.
1.
Unplug the dehumidifier.
2.
Check the surrounding area
for possible reasons for sud-
den temperature changes.
3.
Wait 2 hours before plugging
the dehumidifier back in for
normal operation.
4.
If the "Error" is still indicated,
please contact customer
service. Call 1-888-876-538
Soleus Air SG DEH 70EIP 6 Operating Instructions Manual Error Codes...
Jul 31, 2017 | Dehumidifiers
The F2 code is on in the humidity window of my Frigidaire dehumidifier? Not in manual. What does this mean?
Good Morning friend, thank you for your inquiry!
I see that you are having trouble with your Frigidaire dehumidifier displaying an error code of "F2". Typically, an "F2" error code stands for a miscommunication error. This could be a possible problem with a sensor or control panel. I would suggest performing a reset and that can be completed by disconnecting the power from your dehumidifier for roughly ten minutes. If you are still under warranty I would recommend contacting your manufacturer to see if any additional assistance can be provided. Hopefully this is helpful. -Matt
Feb 13, 2015 | Frigidaire Dehumidifiers
Frigidaire dehumidifier has a F2 error and will not operate
Hello - Typically error code F2 indicates a sensor failed has occurred on the dehumidifier. You may want to contact your manufacturer to verify if the part is available and can be replace. Some do, some don't. Also confirm if the unit has a limited warranty on such concern.
Oct 20, 2012 | Whirlpool Dehumidifiers
Bucket full light flashes, humidity setting won't change - only says 01
Here is a tip that explains what can be happening to make the dehumidifier showthat the bucket is full when it is not.
Dehumidifier Problem It shows Bucket Full
heatman101
Jun 07, 2011 | LG LHD459EL Dehumidifier
How to fix f2 message? what is wrong?
If the display reads "F1" or "F2", a sensor has failed. Contact your Authorized Frigidaire Service Center.
Feb 21, 2011 | Frigidaire FDF50S Dehumidifier
My dehumidifier is giving me a F2 error message and isn't running
When I searched this error code, I found that F-2 means bad sensor. I found no further information as to what sensor it was. You don't give the name of the manufacturer, so I couldn't search from that perspective.
If it is a bad sensor, you may require professional repair.
Before I took it anywhere to be worked on, I would be certain that the catch bucket was setting square (indicating no water in the bucket).
Thanks for your interest in FixYa.com
Dec 26, 2009 | Dehumidifiers
F2 ON THE DISPLAY / WILL NOT RUN / MODEL FDB30R1
hello sir/mam
this is because of the error in the programme so please switch OFF for 1 mint and switch ON then see the display.
Oct 08, 2009 | Dehumidifiers
Dehumidifiers Logo
2,580 people viewed this question
Top Frigidaire Dehumidifiers Experts
Alan Chouinard
Andrew Taylor
Andrew Taylor
STEVE
Are you a Frigidaire Dehumidifier Expert? Answer questions, earn points and help others
