Lg wm2277 soap dispenser stuck
Jg wm2277 dispenser stuck closed
  • 15,935 Answers
It appears your dispenser solenoid has failed in this instance... or the soap has hardened - preventing the door from opening.
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 15, 2010
Anonymous
SOURCE:
The soap dispenser only closes after several tries. At the end of the cycle, the soap is wet and stuck in the open dispenser
May want to try liquid detergent instead. Sometimes using too much detergent will prevent the dispenser from opening and then the soap turns into a wet glob in the dispenser.
Mar 15, 2016 | Dishwashers
Dispenser drawer stuck closed
A common issue on older lg washers, since fixed with a redesign on newer ones. The immediate solution is to take washers top off and partially take dispenser tray apart to free it. The issue is the fabric dispenser is slightly ajar and catching on a lip of the dispenser top and jamming the tray. Thoroughly cleaning tray and all parts will fix but a more foolproof permanent solution involves filing down the leading edge of the fabric softener tub to a rounded edge so it will never happen again. Not easy, but doable. Two screws in back to take top off by sliding it back about two inches and lifting off. Good luck
Apr 02, 2015 | LG Washing Machines
Howto repair refrigerator water dispenser
There is an electric water valve, usually at the lower back of the appliance which would appear to be stuck open and would need to be replaced OR the switch in the dispenser area is stuck in the closed position. Try disconnecting the wiring to the valve and if that stops it then most likely the dispenser switch is defective, If not then the valve is likely stuck open. There should also be a small valve in the water supply line, under a sink or etc. that you can shut off to stop the water flow with until you get the other problem daiagnosed and fixed.
Sep 08, 2014 | Hotpoint Refrigerators
My undersink RO system leaks at all four tube connections on the manifold. I inspected the fittings and the o rings are fine. I inspected the tubes and I cut off the ends of each piece to make sure that...
The quick connect fittings need to be fully seated or when pressure is applied they will leak. If the feed is pressure is high to the RO I have seen this occur also. JG John Guest makes a small locking clip that goes on these fittings to hold them tight. Here is a link to JG which shows this application.
http://www.johnguest.com/Home/applications/beverages-and-drinks-dispense/Inch-Size-Accessories/LOCKING-CLIP.aspx
RJ
Sep 05, 2010 | Culligan Under Sink Water Filter
Ice dispenser stuck on
Either the paddle for the ice/water dispenser is stuck or you have a bad microswitch behind the dispenser.
To stop the ice/water from dispensing open the freezer door and press or hold the child lock button down. Once the unit is in child lock mode you can shut the door without energizing the dispenser.
Another option is to remove the upper freezer door hinge cover and disconnect the wire connector up there. This will remove voltage from the dispenser as well. Then either replace the paddle or switch. Sometimes the paddles/switches will get stuck because of splash up from ice dropping in sugary drinks.
May 05, 2017 | Amana ASD2328HE Side by Side Refrigerator
Ice dispenser appearing to get stuck in the open
The noise is probably the solenoid which operates the door or the one that switches it from cube to crushed ice. Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} You'll have to look to see what's wrong.
Remove the dispenser cover by gently prying starting at the bottom going round and round a little at a time to prevent from breaking it. When it's off the screws will be exposed to access the other components.
Here's a diagram of the dispenser which may help.
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=48122&diagram_id=656733#d656733
Jan 08, 2010 | Maytag MZD2768G Side by Side Refrigerator
Soap door latch won't latch close
Make sure the dial that you turn to start the dishwasher is all the way to the beginning. Sometimes my little grandson comes by and plays with it, turning it. I load, add soap and the dispenser won't close. I check the outside dial, and sure enough, set it to the very beginning and the dispenser locks in place!
Nov 04, 2007 | GE Nautilus 24" Built-in Dishwasher
Sticking dispenser drawer
no other way then force but having got it out you should try to estabish why it is sticking
Apr 01, 2007 | LG WM-2277HW Front Load Washer
Washing Machines Logo
148 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
Marvin
Marvin
