I cannot make or receive any calls on my new mobile phone. i keep getting the error message ''emergency calls only''. i have tried removing/replacing both the battery and SIM card several times. how do i unlock a samsung sgh-c270 mobile phone for free?
SOURCE: samsung SGH-x475 t-mobile unlock code
sure the unlock code goes as follows... *2767*6903557610011172#
after you do that it will seem to shutoff but leave it and it will then open up to working screen... you will have to enter this code each time you turn off the phone but it should work,,, if u have any questions... e-mail me at [email protected]
SOURCE: got a samsung sgh f480 unlocked but cannot use
It should say Limited Service.
Check the IMEI by pressing *#06# it should be all zeros. o2 does not allow this serial code but you could use any other network with the phone. You cannot fix this because it is illegal to change serial numbers on wireless equipment.
SOURCE: reset
my samsung sgh-U700 is not allowing me to make any calls other than emergency calls, and i also can't receive any. How can i fix it?
SOURCE: my samsung FG480 won't receive calls or txts,
sim card is bad...buy a new one and just visit the fone network company to give you back that same number you were using.
Open the Samsung A737 page at any of these sites: My Unlock Code, GSM Liberty, Unlocking.com or Mobile Unlocked. All four of these are pay sites. Mobile Unlocked and GSM Liberty offer money-back guarantees in case the code will not unlock the phone.
Remove the Samsung A737's battery. When the site you chose in Step 1 prompts you for it, type in the International Mobile Equipment Identity (IMEI) number from inside the Samsung A737's battery compartment. Every site in Step 1 needs the IMEI to generate an unlock code specific to your phone. Pay for the unlock code. In case you do not use a credit card, most of these sites will accept a PayPal payment. You will receive the unlock code by email, usually in a few hours, depending on which site you chose.
Slot the old carrier's chip into the battery compartment, in case the unlock code will not work without it: some unlock codes are network-specific. Put in the battery and close the battery chamber.
Enter your Samsung A737's phone mode. Type on your keypad the code precisely as it appears in the email. If you receive the unlock code "A5966J Send" for example, then type in 259665, and then "send" the code to your Samsung A737 by pressing the Talk/Call/Send button.
Slot the new network's chip in under the battery. Make an outgoing call to test if the phone is now unlocked. If the call does not go through and a chip or SIM error message pops up, repeat Steps 3 and 4 a few times. If you still cannot make a call, contact the code provider so they can remedy the problem.
Have you found unlock code for the sgh-c270? I have 2 of them to unlock. Tried a online unlock service but they said they didin't have the code at this time and refunded my money... [email protected]
