I have a Maytag Side by Side model MZD2665HEB and ice maker makes noise. I took icemaker out and cleared out ice that was frozen in both the feed tube and ice maker. It worked good for a day or 2 and now is frozen up again? Bad water valve or ice maker?
Possibly a bad valve but more likely not enough water coming to the unit,follow the water line from the back of the unit to where it hooks to the pipes there is usually a little saddle valve there,try closing it all the way and then open it back up check the water through the door and see if the pressure doesn't improve.
You can also remove the Ice maker clear out the fill tube and sit a cup under the end of it for a day or two if you get water in the cup and Ice in the tube you probably have a solenoid valve that isn't closing completely.
