How can i check lamp life of my Mitsubishi multimedia projector xd450U
I believe you hit the up and down arrow and the enter button on the projector itself and hold hem in for few seconds and it will display lamp usage.
Thank you this worked for th XDU 2000U
HOW TO CHECKED THE USED HOURS SANYO MAKE,MOD-XU47,SR NO.66Z07664
For this projector, you press and hold the reset button for about 5 sec, and it will pop up on the bottom.
Watch out not to reset it though, to get it to go away, just dont touch anything for about 30 sec and it will go away. Only reset if you replace the lamp.
How do i know if my lamp light went out
If you mean how many hours you should get out of a bulb, it should tell you in the manual. To check the bulb hours you should be able to go to the info screen and it should tell you in there.
Please dont forget to vote this answer was helpful and accept my answer.
Many thanks
I have the same problem with the SD430 - I need to check the bulb life and don't know how or where to find the info - any suggestions?
i have the same problem on a hc3000u.. anybody have a solution???
