Question about Hitachi 50UX58K 50" Rear Projection Television
Model 50UX58K - picture has distortion & shadow on right side of screen
  • 587 Answers
Hi, if the shadow is colored lines then you probably need the convergence ICs and possible reisitors near them replaced .
If the shadows is just like a ghost of the image or a bar from top to bottom, then check if it does it on every input (dvd for example) , there are blanking bars that you can't see past the edges of the picture and when you have a bad cable signal you can see the ghost of the blanking bar sometimes. if it does it does not show the shadow when watching a DVD then its a signal issue with your cable/satelitte .
If your convergence is the issue, try the adjustments first and if that doesn't correct it, you can replace the ICs using kit # x480293 or stk392-110 (2 ICs) soldered in very technical for even a technician.
repairman cost about $250-$350
hope this helps
Eric
I’m happy to help further over the phone at https://www.6ya.com/expert/eric_ab7c09ec01841771
Posted on Sep 01, 2009
Anonymous
SOURCE:
LG MODEL 55LM4600 THAT HAS A VERTICAL SHADOW ON THE RIGHT SIDE OF SCREEN ABOUT 3 OR 4 INCHES WIDE. hAVE YOU HAD THIS BEFORE?
Line fault. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Line, faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent.
Jun 03, 2015 | LG Televison & Video
Toshiba Flat Screen TV Model TZ61V61 Serial #23960912 problem with wiggles and shadows in the corners
Could be video card or screen its self. Does it start out with distortion as soon as tv is turned on or does it distort as it warms up?
Mar 01, 2015 | Toshiba Televison & Video
Red & green shadowing on the right side of picture
First thing to try is a convergence but with the red shadowing seems to me that you may have your color gun going. Convergence can be found in your video menu on your setup screen. Once in the menu you can adjust the colors to line up. This usually has to be done on a tv that has been moved.
Nov 11, 2012 | Hitachi 60EX01B 60" Rear Projection...
Shadows and not so bright picture
Convergence is the problem. You can get instructions and parts frow www.TvRepairKits.com
Jun 22, 2009 | Hitachi 50UX58K 50" Rear Projection...
Picture is distorted from center on my 65
You do have a failure in the convergence circuit of your set. If you are good at soldering you can replace the IC's yourself. They are on the large circuit board on the left side of the set looking from the back, and attached to a large aluminum heat sink. If you don't feel comfortable doing that, I reccomend removing the board and sending it to PTS corp in Indiana. They are pretty reasonable repairing boards, and a lot less than buying a new one.
May 31, 2009 | Sony Grand WEGA KDP-65WS550 65" Rear...
Picture is distorted from center on my 65" Sony projection TV.
hi. this will be an easy fix for you if you are a good solder. you will need to replace the convergence chip that is located on the PC board(main). this chip is damaged and it has failed due to this damage that has occurred. click below for your new convergence chip(stk).
CLICK HERE
May 21, 2009 | Sony Grand WEGA KDP-65WS550 65" Rear...
Shadows/ghosting is present on screen at all times
What kind of shadowing are you seeing? Doe the picture look like a 3D movire (colors separated)? What is the make and model?
Please update this with the above info and I'll provide possible solutions.
Thanks,
Dan
Mar 20, 2009 | Televison & Video
MODEL NO SP42W4HB PICTURE DISTORTED TOP AND RIGHT SIDE COLOURED SHADOWS COLOURED WAVY LINES TOP THIRD SCREEN PINK AND GREEN
This is most likely a convergence problem. You should see 2 large black ICs in side attached to a heatsink. They will be marked STK392-010. Try resoldering the pins on these ICs first. If that does not resolve the problem, replace them. These parts will be about $20 each.
Keep us posted.
Dan
May 28, 2008 | Samsung Televison & Video
Red Convergence on JVC AV- 65WP74
convergence amp ic bad
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Sony Convergence
http://www.techlore.com/blog/entry/19694/Sony-Convergence-Repair-My-Sony-TV-has-a-distorted-picture-/
http://www.techlore.com/article/19631/Sony-Convergence-Procedure/
Jan 28, 2008 | JVC AV-65WP74 Rear Projection Television
Televison & Video Logo
78 people viewed this question
Top Hitachi Televison & Video Experts
matt martin
matt martin
Todd Hill
Todd Hill
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
