50 inch samsung lcd tv clicks on and off when turn on but no picture
The Fuse needs to be Replaces, contact nearest samsung service center. would cost just $1 trust me
email me if you need any assistance ... [email protected]
Yes trust me its the Fuse problem in your LCD TV,.
IT WORKS like this
when you power up your TV it goes through a small SMPS -- Switched mode power supply, it has a built in Fused and due to interuppted voltage or any issues with VOltage, it would burst the Fuse without supplying the power to the SMPS>>.
So the fuse needs to be changed and it cost abt $1 ...
Have problem with samsung TV plasma going blank screen with sound still happening..all cables are good and it is TV that has problem ..will resetting firmware do the trick ;..or is it a fuse ..or what
darin
no loose cables no picture either tv dosent want to turn on when i push the power button all you hear is that its trying to turn on but it dosent
Are any of the video cables loose? Do you see any channel or video source information on the screen?
