no no don't flash the bios , the wlan problem is related to wlan driver go to my computer and then right click , manage then device manager if network adapter has a yellow question mark you will have to reinstall the driver if no you will have to connect manually . control panel, internet options connectionc , lan settings , click on the automatically detect settings close everythng
reset the cache setting and restore the handset and try from " go to address option",, u will be able to access thes services, try using the opera mini browser for n73.you can just search on google and can easily download and transfer to your cellphone.
You van call the customer care of the service provider and ask for the settings andsettings can be entered in Settings > Connection > Access Points.
If it does not work enter the settings and switch off and switch on again .
And atlast check whether the packet data connection is switched to 'allowed' in the settings.
In order to solve the internet problem in phone kindly check:
*whether your gprs connection is active.
*configuration settings are properly filled.
*home page is properly set.
*verify whether your staying, where you get range.
"IF YOU THINK MY SOLUTION IS HELP FULL TO YOU,THEN DON'T FORGET TO RATE ME"....THANK'S
just go to the web and change the setting so that you can easily connect to the net if u wannt to connect with your p.c with mobile then just open the mobile suit then go to connect to the internet and connect the net your network customer can may help u to connect with these problems
check ur service settings . if ur using phone as modem . then inform me . if u r browsing in phone u may not have configure ur proxy or port address in sttings .
