SOURCE: new wireless network - now my airport express and airtunes does not work
thanks so much - vey helpful!
SOURCE: DI 524 and airport express
Yes, that is possible for as long the DI524 is already properly setup and can provide already internet connection everything should be working fine there....
SOURCE: New Apple Airport Express Base station blinking amber light
Using the Airport utility on your macbook (located in your Utilities folder) will tell you what the conflict is.....most likely you have DHCP issue or the network is at the incorrect setting.
The wizard in the utility will tell you what you should fix.
SOURCE: I can't connect apple airport expresses with a siemens 587 route
When doing this keep your password to 13 characters as different companies apply different defaults to make up the required 13
SOURCE: How/where do I connect tivax digital convert to my loewe Planus
The converter box has multiple ways to connect,but its really meant to convert a digital signal to analog. That's why the output channel for the converter is usually either channel 2 3 or 4 and you change the channel on the box rather than the tv. The box can be hooked up to the tuner which is the metal connector for antennas or cable. You can also use the composite hook ups as well (red and white audio, yellow video ) Just check which input on the tv your plugging them into so you know which to select for viewing. Signal out of the converter box,to video (av) in on the tv and you're good to go.
Ryan Bauer is a freelance writer located in Ozark, Missouri. He has written numerous articles and books, including "How to Improve Your Credit Score 100 Points in 100 Days." Bauer is an experienced automotive mechanic and computer technician.
By Ryan Bauer, eHow Contributor , last updated February 24, 2012
Wireless routers are used to connect computers into a network without running network cables throughout your home or office. Netgear wireless router settings must be changed using the router's Web-based interface. Any computer that is "hard wired" with a network cable to the router, rather than on a wireless connection, can be used to access the router. From the Settings menu, options such as "Encryption," "Network setup details" and "Passwords" can be customized.
On a computer that is connected to the router with a network cable, open any Web browser, such as Internet Explorer or Mozilla Firefox. In the address bar, type "192.168.0.1" (without the quotes) and press "Enter." This will bring up the login prompt for most Netgear wireless routers. If that doesn't work, try "www.routerlogin.net", "192.168.0.5", or "10.1.10.1" until the login window appears.
Type "admin" in the Username field, type "password" in the Password field and click "OK." If the password fails, try "1234," "Password" with a capital "P" or "admin". Once you enter the proper credentials, the settings screen will open.
Make any required changes to the settings. Under Security section, it is possible to specify a new username and password for added security. Once you have saved your changes, close the window, and the system will automatically log you out.
