Klv32s310A sony bravia gets start on with green light and after a second turns to stand by mode blinking the red light 6 times after each 2 second interval
Hello Sagar,
green led means tv powered on and status ok.
Red blinking light almost always means defect, overcurrent or overload.
6 blinks for Sony lcd flat tv means trouble in backlight circuit, or backlight inverter (backlight illumination or lighting makes your tv screen visible).
common problems in the inverter circuit, which drives the backlight, or shorted drivers, or short-circuit transformers or open circuits.
You should find the problem in the inverter circuit, or in the power supply board or in the main board.
Also look for bad capacitors (electrolytic caps) which are bulged and swollen on top.
Decoupling plugs from printed circuit boards can help you in finding the problem board by elimination method.
If you power up the set after unplugging certain plugs on f.e. the inverter board , this could result in getting a green power led and concluding that this board is faulty.
succes,
Walter from Antwerp, Belgium.
dryer says 8.8 and we have reset breaker and unplugged but still won't start. it has done this 2 or 3 times but eventually it will start working.
thanks
linda
Same problem - tried the same solutions with resetting breakers and unplugging - happened twice before - finally corrects itself - but not this third time
we just bought our dryer a couple of weeks ago...and should have know better due to the troubles we have with our Maytag wash machine that get's repaired every other month or more. We have the same 8.8 come up on the panel.... I will try the suggestions and hope that this machine will not cause as many problems as our wash machine.
