After loading the LWP file I get a Command or filename not found after my PDT6842 boots up. So I then load the UPD file and get the same. Is this a normal screen to get? Am I on the right path in getting this scanner setup?
Command or filename not found. This happens when you have a hardware fault associated with the flash or main custom chip. Seen this soooooo many times it’s untrue. The zip file is unable to extract properly. If you pay attention to the system whilst it’s extracting you will see the error.
Incorrect LWP and UDP versions would usually just fail at "RF Drivers Failed to load"
If you need any more help then please do not hesitate to contact us:-
[email protected] or TEL 01202 620955
http://www.biastechnology.com/
You might be loading inccorect LWP or there is a hardware problem, in any case we can help. You can always contact me by phone or email 630-622-2024 [email protected] Please visit our website www.legacyglobal.com
