Question about Sansui Televison & Video
My sansui flat screen volume works but the screen is black and I can't get a picture. What should I do?
I've turned the TV off and back on,that wouldn't work. I've also unplugged my sansui flat screen and plugged it back up and the picture still didn't come in only the volume. What should I do now?
Anonymous
SOURCE:
Anonymous
SOURCE: No Audio on 32 Inch LCD Flat Screen
If there's no sound at all, switching channels or not, then you may want to check this out:
http://bobbykolev.blogspot.com/2007/11/insignia-ns-lcd32-32-tv-power-sound.html
Posted on Nov 18, 2007
Anonymous
SOURCE: goodmans flat screen TV.Blank screen
If it is a LCD TV, and there is a faint picture, it is probably the backlight or inverter board (probably the latter). This is a common problem (especially with PC monitors).
Do an internet search for your model and inverter, you may be able to replace it.
Make SURE you REMOVE the power lead before opening the set !!!!
Posted on Mar 03, 2008
Anonymous
SOURCE: Samsung LCD Flat Screen TV LN-S2651D - Volume Problem
I lived with it for about six weeks, then took the back off the TV. Just now it seems to be fixed, but I don't know if it will last.
I disconnected the wire leading to the channel up/down, volume up/down and source board, turned on the tv, turned it back off, reconnected the cable, and everything seems fine now.
Posted on Mar 14, 2009
B52Tony
Tony Nguyen
  • 96 Answers
SOURCE: Vizio GV47L screen went black and is now unresponsive
Change the main board if you have good picture and sound. If you don't have picture and sound, the inverter will also need to be change.
Posted on May 30, 2009
TStevens
  • 110 Answers
SOURCE: 47" Vizio Flat screen HD LCD freezes up and remote will not work.
could it be Ch 9's digital signal is not broadcasting right? what is your refresh rate on your tv? 60 or 120hz? if its 120hz, then its more then likely the digital broadcast, if its 60hz I think its your tv can't keep up with their signal that may be at 120hz. Make since??
Posted on Apr 28, 2010
Yesterday my sansui was not showing any picture although it was on,the screen was cold. today the power button does not turn on.
Sansui HDLCD3700 -- Turns On, No Picture/Sound - Badcaps Forums ...
www.badcaps.net > ... > Troubleshooting TVs and Video Sources
May 20, 2013 - 7 posts - ‎3 authors
Sansui HDLCD3700 -- Turns On, No Picture/Sound ... My Country: USA ... not been able to get any sound or video at all (no backlight either).
Sansui hdlcd185w repair - YouTube
? 2:25
https://www.youtube.com/watch?v=qMpiC8YL3SE
May 31, 2013 - Uploaded by After Hours Tv & Pc repair
Thanks so much for posting, saved my kitchen tv from the landfill!... Also the buttons on the side of the tv do not work correctly. ...Any suggestions? .... LG LCD TV REPAIR - NO PICTURESCREEN FIX REVIEW - Duration: 5:29 ...
Jan 08, 2016 | Sansui Televison & Video
TOSHIBA LED 46L5200U TV where picture stoped working and the volume is working
Check and replace its back-light inverter board. Contact any service technician. Gopakumar Gopalan Google
Feb 24, 2014 | Toshiba Televison & Video
There is no sound with black screen
depending on how much you leave your TV on, it could be that internal chips could have fried and needs a tech to replace parts for picture and audio from manufacture.
Dec 18, 2012 | Sansui 19 in. LCD TV
Picture shows for 1 sec when switching on TV, and then screen goes black on my Sansui TFT SV-2010 LCD Monitor
Now u turn on the tv the tv pictures only flashes a few sec.than dies,but the tv still have audio sound left only?Yes,mean ur tv have a 1 or 2 long boards that are call a LCD inverter boards are the causes and the problems.These 1 or 2 long LCD inverter boards only job are to provided the tv LCD screen panel for a backlight for the tv to have picture only.Tries websites like Shopjimmy.com,Ebay.com to buy a 1 or 2 the tv long LCD inverter boards for the replacement.
Oct 03, 2011 | Sansui HDLCD3210 32 in. LCD TV
I hv sansui flatron tv and from 1 month i hv problem in my tv that my tv screen black after few minutes but sound is on but screen black and after sometime it will reappear. and some time it work...
If possible eaily take it straight back to the shop it came from or whatever advice the instruction book tells you depending on where in the world you are.
Sep 20, 2011 | Sansui 19 in. LCD TV
TV is connected to cable; when we have a picture it is terrific. There are several times during the day when we have audio but screen is black. Unplugging and waiting an hour or more sometimes helps but...
Return it to Amazon.com.Get a replacement tv.This tv have problems with it 1 or 2 long LCD inverter boards,it dying going to be dead.That why u have only a flashes of a picture only a few second,than died,just black screen lelf and have sound.Or talk to Amazon.com customer serviced to get ur tv a warrenty repair.
Nov 14, 2010 | Sansui HDLCDVD325 32 in. LCD TV/DVD Combo
Two screens on screen separated by a black line
take the tv back to the dumpster and leave it this time
Dec 30, 2009 | LG 42LC2D 42 in. LCD HDTV
Was watching tv all of sudden screen turned black, with audio...
i was watcing tv afeter a while i realized there is no picture but we have sound
Jul 14, 2009 | ESA PDP4294LV1 42 in. EDTV-Ready Plasma TV
Why would my t.V. go black after three to four minutes
This Sansui set has been plagued with problems and is now fast becoming a dinosaur. Repairs are not cheap and as this is a low HD non-HD tuner set its probably time to think about an upgrade anyway to a full HD set with built in HD tuner.
The set was made in China and sold through Kmart but has no real support here or from the makers.
If you dont intend to do anything with your TV I would very much like the Remote control as mine is broken.
Please email me at tminbox@hotmail.
Jul 11, 2009 | Sansui HDLCD3210 32 in. LCD TV
Could be the power supply gone bad.
No easy solution I'm afraid.
May 20, 2009 | LG 47LC7DF 47 in. LCD HDTV
Televison & Video Logo
32 people viewed this question
Top Sansui Televison & Video Experts
matt martin
matt martin
Ekse
Are you a Sansui Televison and Video Expert? Answer questions, earn points and help others
