Washing Machines Logo
Todd Hamlin Posted on Jul 19, 2019
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Needing to remove lid from our top load LG washer. Model #WT7100CW. There are no screws along the side or access doors to conveniently get to screws like many of the other models I’ve seen. This washer is less than a longer old. Thanks!
  • Todd Hamlin Jul 19, 2019
    **less than a month old (not longer old)
robert
Level 3:
  • LG Master 2,548 Answers
  • Posted on Jul 20, 2019
robert
LG Master
Level 3:
Answers
2548
Questions
0
Helped
869910
Points
8043
Most top load washers have snap clips in front and hinges in back. You use a putty knife or equivalent to push in the clips(located between top and front of unit in the seem). Some others have screws on bottom near the legs that you unscrew and tilt front forward and then lift up and off. Good luck.
5 Related Answers
Anonymous
  • 878 Answers
  • Posted on Apr 15, 2007
SOURCE: replacing lid switch
someone, Im not finding that model number. Going by the first six digits Im assuming that this is a regular top loader and not an Oasis washer. If so, remove the end caps on the consol by pulling them off. Remove the screws under each end cap and flip the consol up. Unplug the lid switch connector and snap springs holding the cabinet on. The whole cabinet will pull forward and you can get at the lid switch. Check out the pics and post back...Catriver.
Anonymous
  • 351 Answers
  • Posted on Mar 21, 2008
SOURCE: removing front panel on maytag washer
some maytag panel just pull off from the bottom,they are just a tight fit.and some have screws under the hob.
Anonymous
  • 750 Answers
  • Posted on Oct 08, 2008
SOURCE: need a diagram for a lid switch
Hello jafarrell
What is the exact model # ?
This was the part number!!
You said, you need a diagram of the Kenmore top loading washer, model 20432 lid switch.
This is a Kenmore part # you supplied, so here is where you can get it from Kenmore.
Part # 20432 lid switch as you supplied in our communications!.
http://www.searspartsdirect.com/partsdirect/retrievePartActionHome!search.action?productGroup=N%2FA&partNumber=20432&pop=flush
Thank you for using Fixya.
Huuum
Please remember to leave a rating
aborcass
Ron Coons
  • 2651 Answers
  • Posted on Nov 21, 2008
SOURCE: Need to replace the screws that holds the drum baffle in place
remove the scresw holding the door on, remove the door, the remove the 2 screws oppisite th edoor inge and the front panel will lift off. there will be 2 5/16 screws holding the top down to the frame of unit, the top will then lift up[ giving you acces to the outside of the drum to resecure the drum baffle
tom weber
  • 198 Answers
  • Posted on Jan 05, 2009
SOURCE: Remove lid of top loading washing machine Kenmore 110.92575110
Remove 2 screws that hold the console in place. Most are at the rear corners of the console. Pull console forward and up and tilt back.There are 2 brass clips holding the cabinet in place. then the cabinet can be removed by tilting forward and away from base. there is no reason to remove the lid.
Maytag neptune washer
what is your model number? If this is a front load neptune, you first will have to removed the four screws around the soap dispencer. Then you have to remove the two screws, to remove the door. Then the two screws on the opposite side of the door hinges. The front panel wil come forward. There are two 5/16 hex head screws, one on each side to remove. Some have brackets you take out, some don't. the lid should then come up
I’m happy to assist further over the phone at https://www.6ya.com/expert/toby_c33c05e2a745c73b
1helpful
After googling I determined that the water inlet valve on my crosley bycw4271 top load heavy duty washer was needing replacement and bought the part. I could probably install it except I can't figure out...
on the control panel there is 2 screws to take the panel off either in the rear or front along the bottom then flip that back and there will be 2 metal clips 1 on each side take flat head screw driver and pry towards the back. unplug lid switch and whole cabinet will tilt towards you for removal and you will be able to access the water valve and more if needed.
1helpful
Washer is not draining. How do I remove the front panel of my Electrolux IQ front load washer (Model EIFLW55HIW) in order to access the drain pump? There is no access panel on the front of the washer....
you will need to remove the lid first then remove the screws that hold the control panel in place.then you will need to remove the door boot on the front panel. there will be two screws on the bottom of the panel that will need to be removed as well as the screws on the top of the panel.
HI I HAVE A DRYER MODEL DLG5988WM I WOULD TO KNOW HOW TO REMOVE THE FRONT PANEL
Step 1, remove dryer top: remove three phillips head screws from the back edge of dryers top.
stand in front of dryer and push back sharply about 2 inches on the dryer's top using the palms of your hands. Lift top up and off.
Step 2, remove control panel: remove phillips screws from back side of control panel corners and release clips along top edge of control panel, allowing panel to be taken off and set on top of dryer.
Step 3, remove front panel: Open door, remove phillips screws located at 4 and 8 O'clock positions at door opening. remove phillips head screws along fron panel's top edge. tilt panel forward and unplug light, door switch, and moisture sensor (at bottom of panel) and then set panel aside and out of your way.
I havde a top load washer . sometimes it doesnt start the wash cycle because its not recognizing that the top is closed. swe have to press on it most of the time for it to start .. but someetimes it stilll...
The lid switch is mounted to the top on the right hand side. First unplug unit remove the control panel one screw in each back of each end panel ,remove main retaining clips and pivot entire washer housing to gain access to internal parts..Also check hinge screws (2 small phillips head) on each side of lid ..the arm on the right side actuates the lid switch if loose could cause intermittent operation
1helpful
What is the easiest way to get the front panel off of my LG front load washer to replace the large rubber drum gasket which ripped? Is it screwed on or pressure fit?
It can be changed out without removing the front panel. There are special tools designed to remove and re-install the spring clamps which hold the gasket on, but you can do it with long nose pliers or other implements. It is more difficult to do with the panel on, but it can be done. If you want to remove the front panel: Remove bottom screws from plastic parts on the back edge of the washer top. Stand in front of machine and use the palms of your hands to sparply push back the washer's top about 2 inches, then lift it off. Remove screws from support frame to control panel. Remove dispenser drawer by opening it and pushing the tab on the top back side down while pulling the dispenser the remaining way out. Remove screws from behind dispenser drawer. Release tabs along the top edge of the control panel (watch out for sharp edges) and swing the control panel up on top of the washer drum. Remove spring clamp from front of rubber door gasket. Open access door panel on lower left of front panel. Use small hose to drain out remaining water. Remove phillips head screw in recess, then use plastic putty knife to push inward on the left or right edge of rectangular housing around the recess to remove recess. Remove screws at bottom from bottom of front panel into frame (located behind plastic recess) Remove screws along top edge of front panel. Tilt front panel forward and unplug door switch. Set front panel to the side.
2helpful
Washing machine filled with water and then stopped mid-cycle. This happened before and the repairman said it is a door switch. He removed the lid and in 5 mins moved something at the back of the machine....
the lid switch for you model is located inside the cabinet of your washer. you should be able to access it by removing the front panel. by inserting a putty knife or similar tool on the left and right side along the seam of the cabinet. you should be able to feel two small clips that hold it in place. lift up SLIGHTLY on these clips and remove one side at a time. once you have done this you may need to release the top as well, held in by two 3/8 hex screws. the lid switch is on the right. and is held in by two phillips screws and a wiring connection as well remove the two screws and the connection and replace it with a 3355458 lid switch. hope this was a help to you
Thanks
1helpful
How to replace lid switch
you should either have screw at both sides on rear of control panel. if not you have tension clamps at right and left side at bottom of control panel in front. use putty knife. flip control panel back. undo lid switch harness. lift lid up and pull lid switch out. remove 5/16 ground screw first
1helpful
Need to replace roller's on LG Tromm Gas front load dryer. The back seems to be stamped to the side panels. How do you take apart the dryer to get at the inner workings?
Unplug power cord. Remove phillips head screws on the bottom side of the "L" bracket on the back side of the dryer's top. Use the flat sides of your hands to sharply push back on the dryer's top, sliding it back about 2 inches and then lifting it off. Remove screw from top corner front corners and pry control locking tabs off from along top edge. (watch for sharp edges) Swing control panel up onto top of dryer. Remove the two screws at the bottom side of the door opening and the four screws along the top of the front panel. Unplug the light, door switch, and also the moisture sensor (by the bottom of the drum) then remove front panel. Remove four screws holding front drum support and lift up on it a bit to remove. Look at how the belt goes around the motor and pulley before removing, then take out drum. You will need to remove the phillips screws from behind dryer to remove the rear drum support assembly, allowing you to get to the nuts on the back rollers. First time job: maybe 2 hours. Second time: maybe a half hour, tops.
4helpful
LG WM0642H*
Remove the 4 dispenser area screws. Depress side dispenser tabs to drop dispenser assembly from the top lid .Insert an opener or flat item into top lid and front panel space to depress inward the metal lid top hold down clip.Do left side first then right.Raise the lid and look down behind lock mechanism.Or tilt washer and look underneath. It's an open area below?
Top LG Washing Machines Experts
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
