Question about Sony BRAVIA KDL-40S2010 40 in. LCD Television
13 standby blinks. Sony KDL-52W3000
TV makes a humm when turned on for a split second then turns off and blinks 13 times. Not 6 then 7. Not 4 then 9. Thirteen perfect blinks stop. Then 13 blinks again.
    President:
  • 1,077 Answers
It's a power supply related issue. It's an error code for a certain circuit pathway, but I'm not sure 100% sure what code 13 can be because I don't have the Service Manual for your exact TV model number. But, here's where you can get one:
http://www.service-manual.net/ashop/catalogue.php?cat=231&exp=&resultpage=108&shop=1
It will have all the info on the trouble codes for your TV. Schematics, Diagrams and Part number list for repairs.
Posted on Sep 03, 2009
  • jctbusiness
    jctbusiness Jan 16, 2012
    Here is a better place to download file. This site is free. the one above is $12.99. you'll see a preview of the manual and an ad beside it( mine showed the gunnar gaming glasses). under the ad is the link. click it and the download will begin. I just downloaded it today so it is working .
  • jctbusiness
    http://elektrotanya.com/sony_kdl-40v3000...
    sorry forgot the link.lol
6ya staff
SOURCE:
LCD TV does not turn on from first time
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
http://electro-medical.blogspot.com/
If blinks continue without any pause, the main board is faulty.
Search the site by type in the "brand name" to your device, in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
Jul 08, 2016 | Panasonic Televison & Video
I have a Plasma TV with black screen and 6 red light flashes.
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. http://electronicshelponline.blogspot.com/
Blinking codes details to many popular brand TVs are given. Surf the site with patience.
May 19, 2015 | Panasonic VIERA TC-P55VT50 55-Inch
I'm assuming that it is an error code. The red
colour wheel issues and defective lamp replacing lamp and light engine color wheel cos its worn out
Jul 07, 2013 | Televison & Video
Pioneer plasma TV. When I power on the red power turns blue, as it should. But then I hear a second "click" and the actual tv never powers up. The blue light will then blink thirteen times over and
if you know electronic repair, what you can do is trouble shooting. you will need to check weather the output voltages from the power supply going to the sustain board doesn't drop or need adjustment.
Oct 28, 2012 | Televison & Video
TV turns off by itself after 35 seconds of being on. Indicator light flashes red endlessly.
The TV is going into protection mode. Could be a problem with moisture. Can you try warming up the rear with a hair drier? Ensure that you do not apply too much heat to avoid damage to plastic parts. If you can remove the back cover (after unplugging the power outlet and switching off the TV), try doing in on the entire PCB, if you suspect moisture is the problem. Please do not touch anything in the board by bare hand as there would be high voltage charge in capacitors even after switch off. If it does not work, this might need attention of a qualified service technician
Jul 11, 2012 | LG 42LD450 42 in TV
Sony bravia blinks 6 times
i have a Sony Bravia LCD TV KDL-60EX645
and it Blinks about 6 times every 25 seconds and it blinks next to the "Power" symbol? what does that mean? i cannot turn on the tv because it turns of and its not on eco and i just got it for christmas. its a 55" and i have a 3 year warrinty. but do i need to pay for it, or will it turn back on later ive been waiting about a week? i am a major gamer i usually spend 14-16 hours using the tv i am a youtuber, but does it burn out? i know alot about tv's but im not used to this error... i need some help so please contact me at Alexcromwell1@live.com
Please help me. i might seem like a slacker but actually i make money of using the tv. thankyou for taking the time to read this and try to help me please. thankyou -Charles
Apr 24, 2012 | Sony BRAVIA KDL-52W4100 52 in. LCD HDTV
13 blinks on standby light
If you can post a few pictures of the boards in the unit to our forum at: http://www.ccl-la.com/forum/index.php Our techs will look over the boards and offer information to guide you in the repair.
I hope this helps, if so please rate our solution.
Buddy
Corporate Computer
www.ccl-la.com
Mar 13, 2010 | Sony KDL-40XBR4 40 in. LCD HDTV
A17w221 goes off automatically with power on
I have the same problem. The next stage is that the picture won't come on at all and the blue light will constantly blink. I think the light source is bad. Noit sure though.
Mar 25, 2008 | Envision A17W221 Television
TV picture won't stop blinking
Sounds like a bad solder joint or leaky capacitor. What make and model set do you have.
Jan 11, 2008 | Televison & Video
Sony BRAVIA KDL-40S2010 40 in. LCD Television Logo
2,316 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Ekse
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
