My camera wont shoot, but will download pix in the computer but wont shoot new pix. Before I insert the SD card in the camera, the SD card switch is in "unlocked" postion, when I remove it, it's back in the "locked" position?!!! Is there something wrong with the card or could it be the camera that's sliding the SD card into "locked" postion?
This used to happen occassionaly with my canon camers. Just use a peice of scotch tape or if you have one a small dab of hot glue to stop it from sliding.
Hope this helps FixYa,
Chris
Testimonial: "Scotch tape worked just lovely!!! Thank you!"
This happened to me with an sd card reader, try and see if theres something stuck in the cameras sd slot that could be sliding the lock switch when you insert the card, or if the sd cards lock switch is cheaply made it may stick out slightly.
