Palm m515 Handheld Logo
Posted on Sep 03, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Fully charged put on cradle fatal alert/fatal exception/reset
Reset then back to the same circle when on cradle battery has a lighting bolt thru it
hmlee390
Level 3:
  • Master 736 Answers
  • Posted on Oct 07, 2009
hmlee390
Master
Level 3:
Answers
736
Questions
Helped
279718
Points
2447
The lightning bolt is normal ..its telling you the battery is being charged .. if you get an error code or if the unit quits working then you can do a reset or a "hard reset" ... the hard reset erases everything and will restore the unit to factory conditions .. to do a reset .. unscrew the top of the stylus .. that gives you a probe to push the reset button on the back (top) .. if you hold the power button in while you do a reset then it gives you a choice to "erase everything" .. if you accept then thats a hard reset ... if everything else fails .. do a hard reset .. you can do all this while its on the charger so if you have a bad battery that wont matter .. if the battery wont hold a charge then it can be replaced ..
2answers
Ipaq 1940 losing programmes during main battery changeover
  1. Plug the charger adapter into the charging port on the bottom of the HP iPAQ Pocket PC.
    Figure : Charging the battery
  2. When the power indicator on the top of the HP iPAQ Pocket PC turns solid amber, the unit is fully charged and can be disconnected from the AC adapter (approximate time to fully charge a unit is four hours).
NOTE: The amber charge light blinks while the battery is recharging and turns solid (nonblinking) when the battery is fully charged.In the event of a low backup battery warning, charge the unit immediately before removing the main battery to avoid data loss. To view the amount of charge left in the backup battery, tap Start, Settings, the System tab, and Power.
Charging with the universal desktop cradle and AC adapter Use the universal desktop cradle to charge the HP iPAQ Pocket PC, or synchronize the HP iPAQ Pocket PC with a computer.
Follow these steps to charge the HP iPAQ Pocket PC using the universal desktop cradle:
  1. Plug the AC adapter into an electrical outlet and connect the other end of the AC adapter to the AC connector on the universal desktop cradle.
  2. Connect the serial or USB cradle cable into the appropriate port on the desktop PC.Figure : Connecting with the cradle
  3. Slide the bottom of the HP iPAQ Pocket PC into the cradle and push firmly to seat it.
CAUTION: To avoid damaging the HP iPAQ Pocket PC or the cradle, make sure the pins are aligned before pushing the HP Pocket PC into the cradle.
    Figure : Charging with the universal desktop cradle
  1. AC adapter into electrical outlet
  2. AC adapter into universal desktop cradle
  3. HP iPAQ Pocket PC into cradle
NOTE: The amber charge light blinks while the battery is recharging and turns solid (nonblinking) when the battery is fully charged.There are stabilizers located in the universal desktop cradle that assist in aligning the unit when there is no expansion pack attached. When placing the HP iPAQ Pocket PC with an expansion pack attached into the universal desktop cradle, the stabilizers will be pushed down by the expansion pack. To release the stabilizers for use without an expansion pack, press the button on the back of the cradle.
Charging with the optional USB Autosync cable Charge the HP iPAQ Pocket PC using the optional USB Autosync cable by connecting the Autosync cable to the HP Pocket PC and the personal computer. The HP Pocket PC will be charged using power from the personal computer.
For more information on charging the HP Pocket PC using the optional USB autosync cable, from the Today screen, tap Start, Settings, the Systemtab, Power, the USB Charging tab, Settings, and Help.
Charging a low battery The HP iPAQ Pocket PC will not turn on if the battery has a low charge (less than 3.2 Volts). Fully charge the battery prior to using the HP Pocket PC.
If the charge on the battery goes below the 3.2 Volts as a result of not being connected to the universal desktop cradle or the AC adapter, no damage will occur to the battery. However, the HP iPAQ Pocket PC charge indicator light will not flash until the battery reaches the minimum charge of 3.2 Volts and a normal reset is performed.
Follow these steps to charge and reset the HP iPAQ Pocket PC:
  1. Connect the HP iPAQ Pocket PC to an A/C power supply.
  2. Charge the battery to the minimum level of 3.2 Volts (this will take 5 to 30 minutes depending on the current charge level).
  3. Perform a normal reset by using the stylus to lightly press the Reset button on the bottom of the HP iPAQ Pocket PC.
  4. Turn on the HP iPAQ Pocket PC.
Keep the HP iPAQ Pocket PC connected to the universal desktop cradle or AC adapter when it is not in use.
Fatal Exception
Make sure you have more than 25% space left on your device and try again. If this fails then try a hard reset: hold down power button and press reset.
For more help:
[email protected]
DEC Electronics Limited
www.dec-help.co.cc
4helpful
3answers
Palm Tungsten E2 error
Everytime I got that error, press soft reset on back and it should reboot normal
Panasonic KX-tg9333
There is an option on the phone you need to access to clear the voice mail call alert light.Check your user manual.
tk46
1helpful
Dell AXIM x50v won't start.
Note: The following is a quote of someone else: I had the same prob. Went to dell site and found this. Take out battery. Put the cover back on. Attach to cradle and turn on. While it is on, do a soft reset. Turn off, take it out of the cradle and put battery back on. Try turning on with battery only.
Know it worked for me except for the last part. when i replace the battery it won't run on...again. tell me what happens with you ^_^
2answers
H6315
I got the same problem. I even tried to plug the battery to the second battery charging slot, still couldn't get it back to life. But the Ipaq screen lights on with progress bar progress for about 5 seconds, then dead again. I even doubted the battery was toasted.
I gave it a final shot:
1. Remove the battery, and then put it back.
2. While the screen lights on, within 2 seconds, cold reset the unit by press the hole with stylus and push the power button at top in the same time.
In my case, the progress bar will keep going until I see the tap screen instruction and everything back to normal. But it reminds me that the removable battery is totally discharged. So I put it in cradle and I am able to synch it with my PC. Everything seems o.k. while it sits in the cradle, except the charging light won't turn red.
When I remove it from the cradle, it still lights on, battery shows 99% which is healthy. but when I turned it off, it won't start anymore. I have to repeat the above steps to revive it. Sometimes I have to remove the battery and wait for a while and then put it back, so that the screen can light on to give me chance to cold reset.
Conclusion: Maybe need a new battery. I will check Ebay to get one.
Please post if you have other solutions.
6helpful
7answers
It won't turn on, bt the battery still charging
Another way I've found to do this is to press the power button and reset button at the same time. Then when you get the message to clear all data press cancel. I get this every time I re-charge my axim in the cradle. Doesn't anyone have a better solution? When it happens I have to reset my time. It's usually a day behind.
2answers
Samsung battery
Green:Fully charged
Amber:Improper connection
Red:Charging
Top Palm Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
ADMIN Andrew
ADMIN Andrew
vince
Are you a Palm Computer and Internet Expert? Answer questions, earn points and help others
