Simple, reset your settings or soft reset but first backup your phone memory when finished get your mmc and resetnit....
Find your solution from the list, Software & Hardware Problems Find Your Solutions for other Nokia Phones:
Nokia N70
Codes:
Nokia N95
Nokia N73
Nokia 6300
Nokia 6600
All the other Nokia Phones.
Funny thread i must say. The man have posted all under solution 2, he found that data somewhere on net, wikipedia most likely hehe and even after he wrote all needed steps to repair this other person say to us that he found solution on other site.
Bulshitzzz
Solution is here under post#2 but only what one need is little technital knowledge and some tools to repair.
If u have no tools then take unit to service centre, people need to make a living out of something.
Thanks.
Manully search kar k dekho
U need to categorize problems notchange all parts...
1st write latest mcu ,PPM; then write good Pm file.
If OK, otherwise go to 2nd step{Search networks manually ,if it shows all networks, then fault and cannot register then its fault of gsm,dcs,pcs amp...IF it does not search any network then ist you reflow PA and also make ant.sw jumper..
Now cheque the network. If it is O.K. Otherwise Filters, c&L&R..
Learn Here How To Service Network Problems
there are two sections in network: 1, Rx section. 2, Tx section. all bros plz use manual searching in mobile phone, testing for Rx section and Tx section.
HOW TO FIND WHICH SECTION IS FAULT Tx (or) Rx?
Testing Rx section
use manual search for Testing Rx section, after searching Rx section good condition means it shows network list like Airtel, hutch, (or) any other network list in your area,
If Rx section bad condition after searching it shows NO NETWORK FOUND
1, after searching it shows network list means Rx section is ok.
2, after searching it shows NO NETWORK FOUND or some networks missing means Rx section is faulty.
Testing Tx section
Use manual search for testing Tx section, after searching it shows network list, then you can choose your simcard network, if Tx section is good condition it shows HOME NETWORK SELECTED, if Tx section is fault it shows NO ACCESS.
1, after selecting network it shows HOME NETWORK SELECTED means Tx section is ok.
2, after selected network it shows NO ACCESS means Tx section is fault.
Information of Rx section components and ics nokia dct-3 tech
1, antenna switch
2, RF IC ( Hagar ic )
3, AUDIO IC ( cobba ic)
4, crystal oscillator
5, filters
6, VCO (voltage control oscillator)
Information of Tx section components and ics nokia dct-3 tech
1, PF IC (PA IC)
Information of Rx section components and ics nokia dct-4 tech
1, antenna switch
2, filters
3, RF IC
5, VCO (voltage control oscillator)
6, UEM IC
Information of Tx section components and ics nokia dct-4 tech
1, PF IC (PA IC)
HOW TO SERVICE Rx SECTION FAULT ?
Solution for Rx section no network found fault nokia dct-3 technolagy
1,clean the pcb well and Rehot (if not ok follow one by one solutions)
1, give antenna switch jumper
2, Rehot the RF IC
3, Rehot the AUDIO IC
4, Reball the RF IC
5, change the RF IC
6, change the AUDIO IC
7, change the crystal oscillator
Solution for Rx section NO NETWORK FOUND fault nokia dct-4 technology
1, clean the pcb well and Rehot (if not ok follow one by one solutions)
2, give antenna switch jumper
3, Reheat the RF IC
4, change the crystal oscillator
5, Reball the RF IC
6, change the RF IC
7, Change filters
HOW TO SERVICE Tx SECTION FAULT ?
Solution for Tx section NO ACCESS fault nokia dct-3 technolagy
1, Change the PF IC
Solution for Tx section NO ACCESS fault nokia dct-4 technolagy
1, Change the PF IC
SOLUTION FOR OTHER NETWORK FUALT
Solution for low network coverage, all models
1, give jumper from antenna contact to cabinet antenna
2, change the antenna switch
Solution for dct-3 technology
When switch on the mobile it shows full network after few seconds its goas down
1, flash - Rebuild ime - UI settings (if not ok follow 2nd solution)
2, check the track from battery +ve point to PA IC, if track is ok then change the good PF IC.
Solution for dct-4 technology
1, write good pm file (if not ok follow 2nd solution)
2, change the PF IC, if still the problem same check the PF power track to battery +ve point
i want to connect my nokia n70 with internet
yes i have the same problem but i dont know what to do ?
any help full comment will be highly appreciated ?
i m an nokia n70 user i have the same problem of no network coverage since last evening !!! please help as soon as possible ?
i tried with gsm and dual mode also !!!
i have also same problem
i'm using my nokia n70 then suddenly the network disappear.i already use gsm and dual mode but it no use.please help me..
no network my mobile n70
n70 network
n-70 network problem
NokiaN70have net work problem
no network
n70 network"Â problem
